Shifting from 4Hi to 4Lo - JeepForum.com
 1Likes
  • 1 Post By mak_v8
post #1 of 8 Old 10-22-2021, 01:20 AM Thread Starter
Zigpeters
The process I use to shift the transfer case selector from 4 Hi to 4 Lo in my 2000 GC 4.7l with Quadra Trac II is to get rolling to around 2-3 mph, put transmission in N and pull transfer case shifter into 4 lo firmly and with steady pressure. I don't pause at the neutral position.
4 Lo to 4 Hi is similar; get rolling around 2-3 mph, put transmission in N and push the transfer case shifter into 4 Hi firmly with steady pressure. Again, I don't pause at the neutral position.
This technique most often results in a gear crunching sound, similar to shifting a manual transmission without fully depressing the clutch.
Am I doing something wrong, or is the crunching sound "normal " to shifting?
Sent from my SM-G998U using Tapatalk
Zigpeters is offline
post #2 of 8 Old 10-22-2021, 03:25 AM
xcaliber81
xcaliber81's Avatar
I dont ever use 4 low but I've always shut the engine off sometimes I gotta put it in N before it'll go in. I highly doubt anyone but me ever shifted my jeep out of awd.
xcaliber81 is offline
post #3 of 8 Old 10-22-2021, 05:33 AM
mak_v8
mak_v8's Avatar
That is the procedure described in manuals; I usually, if the situation of course allows it, shift from Hi to Low and from Low to Hi with the jeep stopped ahd the transmission in N
fxer82 likes this.
Grand Cherokee WJ 4.7 V8 HO. m.y. 2002
mak_v8 is offline
post #4 of 8 Old 10-22-2021, 07:42 AM
Mr. Bitey
Mopar Nut
Mr. Bitey's Avatar
Ditto. Manual say 2-3mph, but I've always come to a complete stop. Trans in neutral, then shift TC. The gears don't always mesh perfect (might be due to my mileage and wear - not sure if a fresh TC does that), so I am in the habit of a pretty firm tug/pull on the TC shifter, depending on which direction I am shifting.
2004 WJ 4.7 N, daily driver
1967 Jeep J100 panel truck (a-rusted development)
1970 'Cuda, 340 4bbl (10.952et @ 123mph)
1972 Dart Swinger, Gen III 6.4l Hemi (11.223 @ 113mph)
1974 AMC Gremlin X, 440 6bbl (sold)
1975 Jeep Cherokee Sport 2-door (in progress)
Mr. Bitey is offline
post #5 of 8 Old 10-22-2021, 07:53 AM
cDee63
cDee63's Avatar
A slow roll, with a firm steady pull on the lever. Stopping is fine as well however sometimes the gear teeth are in line with each other and that will not allow the shift to happen, slow rolling lets them mesh.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #6 of 8 Old 10-22-2021, 08:43 PM Thread Starter
Zigpeters
Thanks folks for all your responses. However, I'd still like to know if others, following the instructions in the manual by shifting at 2-3 mph, experience a crunching sound, especially going into 4 Hi. I am trying to figure out if the crunching sound is "normal" or if there is a problem with my TC.
post #7 of 8 Old 10-23-2021, 04:52 AM
mak_v8
mak_v8's Avatar
The crunching sound is normal, there are no synchros that help engagement between gears; it's like engaging reverse with a manual transmission while the car is slightly moving.
Your Tcase is like all WJ's TCase
mak_v8 is offline
post #8 of 8 Old 10-23-2021, 07:34 AM Thread Starter
Zigpeters
[QUOTE=mak_v8;41378249] it'like engaging reverse with a manual transmission while the car is slightly moving.
Thanks mak_v8. Your analogy above is exactly what it sounds like. Good to know it is "normal ".
