Shield for fuel filler lines & evap container - 2003 Grand Cherokee - JeepForum.com
post #1 of 37 Old 07-23-2020, 12:17 PM Thread Starter
HarveyCat
I need the shield for around the fuel filler lines & evap container for my 2003 Grand Cherokee - I can give photos if need be! Mine rusted out. I think the 03-04 might be different than earlier years.*
HarveyCat is offline
post #2 of 37 Old 07-23-2020, 01:45 PM
BeetleCamry
BeetleCamry's Avatar
I need this too. Mine is slightly rusted. New piece just bolts in?
2004 Grand Cherokee Special Edition / Quadra-Trac-2 / Midnight Blue Pearl
BeetleCamry is offline
post #3 of 37 Old 07-23-2020, 09:35 PM
Golden-Arm
Golden-Arm's Avatar
may the fastest guy win.
https://www.factorymopardirect.com/o...ket-53013463ah
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
post #4 of 37 Old 07-23-2020, 10:23 PM
Jeepinpgh
Ya, this is probably one of the most rust prone parts of a WJ, either this or the rear brake dust covers. If you live in a rust prone area it will be hard to fine a good used one. I went to two different u-pull yards and probably looked at 20 WJs before I found one that was salvageable, but only paid $10 so was worth it. Pictures below the rusty one I took off, and the used one I salvaged after sanding and priming and painting. It need not be perfect, all it has to do is hold the evap canister and purge pump and valve, but if it completely rusts away the weight of these components flailing around will put stress on the hoses and that is bad.
Jeepinpgh is offline
post #5 of 37 Old 07-24-2020, 06:31 AM
CarlJH
2003 WJ
this was mine after it basically just fell apart as I started to remove it!
not including the horse shoe! Got a new one from Rockauto since I'm in the UK and Jeep parts are quite a lot harder to find at reasonable prices.
CarlJH is offline
post #6 of 37 Old 07-25-2020, 01:31 PM Thread Starter
HarveyCat
Thanks all!
So I bought a new fuel filler neck, a new Mopar bracket & also ordered a Dorman skidplate for the tank. At 120,000 miles on my 2003 - should I also change the fuel pump for good measure while I have it all apart?
Also does anyone know what size & length of fuel lines I will need to buy? Or what size bolts for the skidplate and/or Vapor Canister bracket? Any other likely things? My friend is a mechanic - but since I am bringing this stuff to him he will want to have everything right then. Otherwise he might just reuse stuff that perhaps would be better swapped out. Here is my rusty old bracket!
http://www.youtube.com/watch?v=XFs7aiwHyGg
post #7 of 37 Old 07-26-2020, 08:48 PM
Jeepinpgh
Hahaha..yup that is about right. Like I say, one of the most rust prone parts of the WJ. Good luck with the repair!
post #8 of 37 Old 07-27-2020, 07:54 AM
Double E
Double E's Avatar
I say do the fuel pump. They are known to die at about 160K or 11-13 years and dropping that tank again is no fun.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #9 of 37 Old 07-27-2020, 11:53 AM
Uniblurb
Uniblurb's Avatar
Agree with Double EE; change out the fuel pump module with a Bosch from Rockauto.
Like others who live in a salt/rust belt my vapor canister bracket is rusted up pretty bad. One of the designs of the WJ rocket scientists I've never been able to figure out is why the heck do they have a square hole at the top of the rear wheel wheel cover where it meets the fender so the driver's side rear spinning tire can dump road salt directly onto the vapor canister bracket area?? The top inside bumper stud/nut is in front of this square hole so I see no reason for it at all!
Granted with the tire traveling forward the road salt water/slush would be thrown underneath and on the bracket but it's also going to be slung up top towards the square hole.
Below is a photo of the square hole in the rear outside wheel well cover I'm talking about. It's the same on the rear passenger side wheel well cover up against the rear fender.
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #10 of 37 Old 07-27-2020, 12:15 PM
Double E
Double E's Avatar
Agree...It made no sense that they moved that entire contraption from the engine compartment after, I think,...2001.
I never hear of anyone having evap codes pop up from that unit in the 99-00 models.
I love my WJ and I'm sure there was some legitimate need for it ...but to be so poorly executed does not exude confidence in the brand for what else they'll try to pull.
Double E is offline
post #11 of 37 Old 07-27-2020, 01:07 PM
xcaliber81
xcaliber81's Avatar
My overland wj is rust free, except for this. I am going to suck it up and get a new one though as I feel its worth the cost after all I have went through with it lol.
xcaliber81 is offline
post #12 of 37 Old 07-27-2020, 05:57 PM Thread Starter
HarveyCat
China should make a stainless one.
post #13 of 37 Old 07-30-2020, 01:31 PM Thread Starter
HarveyCat
Success!* Put on new filler tube & new bracket for evap canister. Hoses looked good - even old filler tube looks good - keeping that... Will test with water but looks very new...
Anyway - did a fill up - just till it shut off - and no issues at all!* Dry as a bone!* Thanks for all the help. Will post photos later.*
Still plan to get a new skid plate and fuel pump sometime - jeep is at 125,000 miles - feels great!
post #14 of 37 Old 08-02-2020, 07:04 PM
UKXJ
Originally Posted by Jeepinpgh View Post
Ya, this is probably one of the most rust prone parts of a WJ . . .
Having spent some time on Saturday evening cutting off the remains of this part on my '98 XJ it's obviously a Jeep (well, perhaps Cherokee) thing - which we're not supposed to understand.
UKXJ is offline
post #15 of 37 Old 08-03-2020, 04:14 PM Thread Starter
HarveyCat
Damn - spoke too soon. Leaked again today. Clearly from tank. Replacing the skid plate and need a new fuel pump. What is a good modestly price fuel pump?
