Scanner not linking - JeepForum.com
post #1 of 10 Old 10-23-2019, 02:13 AM Thread Starter
Shazshireen
Scanner not linking
Hi can anyone tell me where to check as my obd2 scanner is giving me a linking error.
Shazshireen is offline
post #2 of 10 Old 10-23-2019, 07:46 AM
Mattyjm
Mattyjm's Avatar
Can you please tell us what Jeep you have? We need year, model, and engine information.
2004 Special Edition WJ. LOADED!
2004 Rocky Mountain Edition. Froggy Bandit. Wife's Daily Driver. PRISTINE! Stock height and may stay that way.....
Mattyjm is offline
post #3 of 10 Old 10-23-2019, 10:13 AM Thread Starter
Shazshireen
9 Grand cherokee Laredo 2001 4l petrol
post #4 of 10 Old 10-23-2019, 10:33 AM
Uniblurb
Uniblurb's Avatar
Check/clean ground G103 which is on the passenger side engine block to the rear of the motor mount on the 4.0. In addition to the PCM using this ground location the data link connector is also grounded on G103. I don't have any photos of the 4.0 in the below ground write-up but there are figures/diagrams under G103.
https://www.jeepforum.com/forum/f310...-info-4192594/
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #5 of 10 Old 10-23-2019, 12:38 PM
Mattyjm
Mattyjm's Avatar
That's a good start. Now, is your Jeep engine running? Does it have a Check Engine Light on?
Mattyjm is offline
post #6 of 10 Old 10-23-2019, 12:56 PM
99wjtx
99wjtx's Avatar
Disconnect the battery, wait a few minutes, reconnect it and try again.
Rage! Rage against the dying of the Jeep.
99 WJ Limited 4.7/NV247
01 WJ Laredo 4.7/NP242
99wjtx is offline
post #7 of 10 Old 10-23-2019, 04:02 PM
BigMateo
Junior Member
If your just pulling codes, why not just use the key trick? Turn the key to the on position 3 times and the codes will appear on the dash.
BigMateo is offline
post #8 of 10 Old 10-24-2019, 09:10 AM Thread Starter
Shazshireen
Trier all the above. Did not work. I have had my key and immobilizer recoded today but that didn't help either. Busy checking the grounding. Thanks
post #9 of 10 Old 10-24-2019, 09:43 AM
222Doc
222Doc's Avatar
might not be the same but our jk did that. issue was the obd2 port had mud in it. this happened right after the Sierra trek at Fordyce trail. i used spray electrical cleaner and wooden tooth picks to clean it out.
222Doc is offline
post #10 of 10 Old 10-24-2019, 10:37 AM
jtec
jtec's Avatar
2014 JK Wrangler
check terminal 16 of DLC for 12v.
try another scanner - this is to confirm if jeep or scanner issue.
jtec is online now
