Rubber brake lines. - JeepForum.com
post #1 of 3 Old 11-25-2021, 04:41 PM Thread Starter
xcaliber81
xcaliber81's Avatar
Rubber brake lines.
After the 2nd caliper piston stuck in 5 years I believe the problem I have is the rubber lines mainly the left front. Rock auto lists a bunch of different kinds and brands from 7$ to 80$ each. Any recommendations? Also im probably going to do the front for now but I see 3 different kinds on the rear Left Right and middle?
Im thinking raybestos is what ill end up with but ive never had to replace them before.
xcaliber81 is offline
post #2 of 3 Old 11-25-2021, 05:32 PM
cDee63
cDee63's Avatar
Yes, the rear consists of three, one at each caliper from the hard line on the axle, those are the left and right. The middle is the one from the hard line on the frame coming from the front, it goes from that line to the hard line tee/axle vent fitting. I used Raybestos on the fronts, mine are the 94mm metal tube ones vs the 205mm metal tube ones, it seems the change is whether the build date is before or after 4/28/03, with the 94mm ones spec'd for build dates after 4/28/03 which my 04 is.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #3 of 3 Old 11-25-2021, 07:02 PM Thread Starter
xcaliber81
xcaliber81's Avatar
Build date of 3/03 so I guess I'm 205 mm phew lol
