rotational pulsing above 45mph... Brakes? - JeepForum.com
 7Likes
  • 1 Post By WJ60
  • 1 Post By xcaliber81
  • 3 Post By mak_v8
  • 2 Post By leadsled jeep
post #1 of 11 Old 07-27-2021, 05:24 PM Thread Starter
Ravenbar
In the last couple weeks, I've developed a very slight pulsing/ out of balance tire wiggle to the steering wheel above 45mph. At first I thought it was an indicator of impending death wobble. I've had 2 weekends off since is starts, and was way too busy or bad weather, so I haven't climbed underneath.
I've had a pulsing brake pedal for a couple months. I replaced the front brakes last year(pads/rotors/calipers/hoses/ABS sensors), so I replaced the rears this year, as I felt nothing through the steering wheel and the rears were a couple years old.
In the last day or 2, I've noticed the steering wheel wiggle is nearly in time with the brake pulsing. Now I'm thinking the brake rotor warp may be hitting the caliper, even with the pedal not depressed, resulting in the wiggle.
Getting ready to order new pads/rotors and a LF wheel bearing as I noticed a slight stiffness to it last time I had the axle apart(only 1 wheel bearing available locally and the RF was def trashed)).
Project Thumper:
KD2QQF
Member of Fourth Coast Jeeps
Ravenbar is offline
post #2 of 11 Old 07-28-2021, 05:18 AM
mak_v8
mak_v8's Avatar
Pulsing on the steering wheel could be due to a little bubble on the tire tread; I remember that when I was a guy, a bubble on a rear wheel caused a little shaking of the rear of the vehicle.
But honestly if this pulsing is also associated to the braking, the cause should be in something that involves the brakes.
Did you checked if one of the front calipers is a little stucked? did you used new or remanufactured calipers?
Grand Cherokee WJ 4.7 V8 HO. m.y. 2002
mak_v8 is offline
post #3 of 11 Old 07-28-2021, 05:52 AM
jay-h
Doesn't need to hit the caliper to cause a pulse, just a slight warpage. Theoretically could be checked and machined but makes more sense to just replace it.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #4 of 11 Old 07-28-2021, 07:28 AM
xcaliber81
xcaliber81's Avatar
I had an unexplainable pulsating at high speed braking for the life of me I couldn't figure out. New brakes, calipers up front pads and rotors all around. Wasn't until the engine went out I decided with the replacement engine it would get new motor mounts. Turns out they were so bad it was causing the high speed pulsating while braking, maybe yours are good and it's not your problem but just shedding some light if you are stumped. Such an odd feeling when your engine actually shifts during corners lol.
xcaliber81 is offline
post #5 of 11 Old 07-28-2021, 08:01 AM
WJ60
WJ60's Avatar
So it stopped when you became a girl ?!?!?
UnekornPrincess likes this.
WJ60 is offline
post #6 of 11 Old 07-28-2021, 08:09 AM
xcaliber81
xcaliber81's Avatar
I was about to say something like that but I changed my mind lol
dauntless89 likes this.
post #7 of 11 Old 07-28-2021, 09:32 AM
mak_v8
mak_v8's Avatar
@WJ60
@xcaliber81
I thought "young guy", I wanted to write "young", ..but I wrote only "guy"...
I had an Alfetta, probably too many drifts...
WJ60, snowbuggy and dauntless89 like this.
mak_v8 is offline
post #8 of 11 Old 07-28-2021, 01:30 PM
jay-h
Nice Alfa. Those old ones had a special character.
[Back in the 50s, 60s and 70s, cars from different countries had different character... British, German, French, Italian, Japanese, even Eastern European all had their distinctive looks.
Now they've all been homogenized...they all look so much alike.[
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #9 of 11 Old 07-28-2021, 01:59 PM
leadsled jeep
leadsled jeep's Avatar
….. I remember that when I was a guy…..
It’s all good here. I identify as a seedless watermelon with preferred pronouns zip/zippah.
WJ60 and dauntless89 like this.
'02 HO 235k ml. BDS, tubular arms, Addco sways. 245-70-17. Amsoil. W1CCW WRKi761
leadsled jeep is offline
post #10 of 11 Old 07-29-2021, 10:35 PM Thread Starter
Ravenbar
I hope it's not a tire. They were new in December. Can't recall if the calipers were new or reman. It was quite a while back on the repairs list as I've been doing a lot of work on it.
I know the pulsing when braking is the brakes. Just not sure if it could also cause something when I'm not touching the brakes.
I'll be ordering new front pads and rotors.
Project Thumper:
KD2QQF
Ravenbar is offline
post #11 of 11 Old 07-31-2021, 06:45 AM
Delta0
A duff tyre Squire?
Delta0 is offline
