Rolling forward while under the Jeep! - JeepForum.com
 4Likes
  • 2 Post By Darnice
  • 1 Post By Bigrigr
  • 1 Post By Klarah523
post #1 of 11 Old 06-05-2020, 04:22 PM Thread Starter
Villegas23
Villegas23's Avatar
Wj Rolling forward while under the Jeep!
So today i finally decided to install a DC front driveshaft and I rocked the Jeep back on forth (idk) and that bad boy actually rolled forward (as if it were in N) and i had to throw my foot in front of the rear tire to make it stop....
Why in the world would this happen???
Now im wondering is it gonna roll into the flowerbox while im asleep?
Thanks
Villegas23 is offline
post #2 of 11 Old 06-05-2020, 04:42 PM
Klarah523
Klarah523's Avatar
Have the parking brake on? I wouldn't rely on the parking pawl on a very used automatic if I was under it, though it's typically older chevy trucks that eat the pawl.
Also -- wheel chocks can be your friend.
2000 WJ (Laredo w/ 4.0L) =|||||||=
Klarah523 is online now
post #3 of 11 Old 06-05-2020, 04:59 PM
JeepRonibo
JeepRonibo's Avatar
2014 WK
Wheel Chocks!
2014 Grand Cherokee Overland V6
2008 Dodge Durango Limited 5.7L
2002 Chrysler 300m Special 3.5L
JeepRonibo is offline
post #4 of 11 Old 06-05-2020, 05:45 PM Thread Starter
Villegas23
Villegas23's Avatar
Also -- wheel chocks can be your friend. [IMG class=inlineimg]/forum/images/JeepForum_2016/smilies/tango_face_grin.png[/IMG]
Well I didn't expect that to happen ha. But is it normal for that to happen when rocking the Jeep? Any ideas on what I can do to test the pawl?
post #5 of 11 Old 06-05-2020, 06:25 PM
Klarah523
Klarah523's Avatar
T/C not in neutral, Transmission in park, it should only roll far enough for the parking mechanism to click in.
If it rolls, it may not be the pawl itself, but could be just the linkage out of adjustment. Or various other things.
IMHO, I've never really relied on any automatic to stay put like I would a manual (I've driven much heavier, much older clunkers).
post #6 of 11 Old 06-06-2020, 04:02 AM
Darnice
Or simply, move the flower box.
Klarah523 and Villegas23 like this.
Darnice is offline
post #7 of 11 Old 06-06-2020, 08:26 AM
Bigrigr
Bigrigr's Avatar
Do you have the 247 full time transfercase in your Jeep? It is well known that these Jeeps roll without the front driveline installed with a 247. Google it and you will find many stories about this. It has nothing to do with the trans pawl, just that the transfer case slips(progressive coupler) without pressure from both drivelines.
WHEEL CHOCKS!
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #8 of 11 Old 06-06-2020, 11:24 AM Thread Starter
Villegas23
Villegas23's Avatar
WHEEL CHOCKS!
242 I'm pretty sure. I'm not out there every day rocking it back and forth but since this never happened before it was new to me. But it's nice to know that it has nothing to do with the pawl. Thank you. I was always wondering why sometimes I give it a lot of gas it "sputters" for about 3 secs and then the sputter stops. Unless that's a different issue?
post #9 of 11 Old 06-06-2020, 11:30 AM
Bigrigr
Bigrigr's Avatar
If it is the 242(true 2wd position up top) then i dont think it will roll away, unless you have it in the 4wd full time position. Then it could roll....
Klarah523 likes this.
Bigrigr is offline
post #10 of 11 Old 06-07-2020, 05:07 AM
Klarah523
Klarah523's Avatar
And this is why I'm here - mostly to learn and to occasionally throw in my $0.02, I forgot about some of the jeep T/C being more like AWD than 4WD.
Might want to take a look at the parking brake if that wasn't holding it.
The sputtering is probably a side issue, first thing is to get codes. That can have various causes: wiring, clogged injectors, bad coil pack, failing plugs, various sensors, etc.
Villegas23 likes this.
post #11 of 11 Old 06-07-2020, 04:18 PM
Bigrigr
Bigrigr's Avatar
Sputtering would be an entirely different issue. Start a new post for best results.
Bigrigr is offline
