Roller Rocker popped off '02 H.O. - lifter or valve seat? - JeepForum.com
 2Likes
post #1 of 23 Old 07-23-2021, 01:10 PM Thread Starter
Ian02WJOverland
My '02 H.O. just popped a roller rocker at Cylinder #5. I limped the motor a mile home under 1500rpm. When I removed the driver's side valve cover a rocker at Cylinder #5 was off. I removed the lash adjuster and doesn't seem to have any issues (doesn't compress at all). I'm going to replace all spark plugs and all lash adjusters. How would you tell visually if it's a valve seat issue? I can't see any signs of the valve or spring damage.
I don't have compression tools/reader at the moment.
Ian02WJOverland is offline
post #2 of 23 Old 07-24-2021, 07:27 AM
cDee63
cDee63's Avatar
Pry it back on and start it, be ready to cut it quick if you hear death noises. If the seat is still intact it will run normal.
Bigrigr likes this.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #3 of 23 Old 07-24-2021, 07:32 AM
Bigrigr
Bigrigr's Avatar
I watched a video of a guy that does this every so often when his 4.7 throws a rocker. He just snaps it back in and drives some more. I would say changing your lash adjusters should take care of the problem if it runs ok after you get it back together.
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #4 of 23 Old 07-24-2021, 08:10 AM
cDee63
cDee63's Avatar
Yep^^. I know some who also put a very thin washer in the bore under the lash adjuster to raise it a bit, the idea is getting a bit more preload on the adjuster. I personally don't like this however it is an option others have used.
cDee63 is offline
post #5 of 23 Old 07-24-2021, 10:43 AM Thread Starter
Ian02WJOverland
Tinkered with it this morning and the space to place the rocker is wide enough to place in there. The valve tip gives as I can grab the top and pull it up 1/3 inch with no resistance and it falls back down. Gotta be the valve then?
post #6 of 23 Old 07-24-2021, 01:34 PM
cDee63
cDee63's Avatar
Yep, you dropped a seat. Go ahead and fill out the poll and check out the horror stories. Welcome to the club my friend!
cDee63 is offline
post #7 of 23 Old 07-24-2021, 03:27 PM Thread Starter
Ian02WJOverland
Oh Jeeez, I bet you're right. It's under warranty, but I'm sure it'll be hell to get it covered. Thanks for pretty much confirming what I suspected.
post #8 of 23 Old 07-25-2021, 11:32 AM
CJREX
CJREX's Avatar
How many miles on your 4.7?
2004 GC Overland 4.7 HO
Powerful Wanderer (wife named it after driving it)
265/70/17 MT, 2" BDS lift
CJREX is offline
post #9 of 23 Old 07-26-2021, 08:47 AM Thread Starter
Ian02WJOverland
I just hit 135K. Bought used from a dealership out of state last year and even with my extended warranty no shop in Austin wants to touch it. Dang
post #10 of 23 Old 07-28-2021, 05:54 PM
cDee63
cDee63's Avatar
It being kind of a PITA job is most likely why they won't touch it. Any head replacement on a V engine is honestly and our's is an OHC which probably sounds much scarier (expensive).
cDee63 is offline
post #11 of 23 Old 07-28-2021, 06:53 PM Thread Starter
Ian02WJOverland
Yeah, that's what I'm afraid of. Warranty coverage states all lubricated parts and specifically everything valve related, though it's at the mechanic right now, I'm still waiting for the official diagnosis. I might be boned, and not in a position to get a different vehicle. Even looking into a new motor install just in case. Yikes.
post #12 of 23 Old 07-28-2021, 07:03 PM
xcaliber81
xcaliber81's Avatar
My H.O developed a rod knock due to the timing chain guides snapping off and being sucked up into the oil pick up.
I got lucky found a replacement H.O from 02 for 1400 Canadian plus all new gaskets and did it myself. Replacement engine had 167000 kms, probably 171000 now. They are hard to find here.
sdg3205 likes this.
xcaliber81 is offline
post #13 of 23 Old 07-28-2021, 07:42 PM
speednjay
speednjay's Avatar
When my rocker popped by out it broke the springs, valves and that was it for my h o.
speednjay is offline
post #14 of 23 Old 07-28-2021, 08:38 PM
sdg3205
sdg3205's Avatar
Must have a good buddy who helps you find engines
sdg3205 is offline
post #15 of 23 Old 07-28-2021, 08:45 PM
xcaliber81
xcaliber81's Avatar
I did lol. I still kick my self for not buying that 04 overland in Kamloops for 2000$ though lol. I probably could have just took my plates down there and just drove it home home too lol.
