Rock Auto Power Stop Calipers Teeves to Akebono - JeepForum.com
 1Likes
  • 1 Post By 97Mule
post #1 of 15 Old 06-17-2019, 08:59 AM Thread Starter
torchd
2003 WJ
Question Rock Auto Power Stop Calipers Teeves to Akebono
So, I need to do brakes, pads, rotors and calipers on all 4 corners. My Jeep (4.7 HO) is a 2003, however still has the Teeves calipers for the fronts. I last replaced my brakes with Power Stop pads and rotor kit; Z23 Evolution Kit 8/2016 about 45k miles ago.
Now, doing some research, it appears that the PowerStop calipers that Rock Auto offers, the front calipers - S4826 are supposed to be AKEBONO calipers? Can anyone confirm this? It doesn't list this part number as Akebono calipers in their description.
I am going to do the whole PowerStop caliper, rotors and pads kit KC2150 which appears to have the S4826 calipers in this kit.
The below pic is their front calipers. they do look like the Akebono calipers...
Thanks for everyone's input!
1998 Jeep Grand Cherokee Laredo
2" BB Pucks | SkyJacker Hydro Shocks | Rubicon Wheels | Cooper 245/75/16 Tires
2002 Trans Am
Cam, Full Exhaust, Stock Heads, Stock LS6 Intake and Stock 10 bolt with 3.42s
420 RWHP and 382 RWHTQ
torchd is offline
post #2 of 15 Old 06-17-2019, 09:25 AM
97Mule
97Mule's Avatar
Go to PS website and look at what u want and order somewhere else!
97Mule is offline
post #3 of 15 Old 06-17-2019, 10:19 AM Thread Starter
torchd
2003 WJ
Why order from somewhere else?
2002 Trans Am
torchd is offline
post #4 of 15 Old 06-17-2019, 02:09 PM
Kolak
Vendor
Kolak's Avatar
The transition to Akebono front calipers occurred during the 2002 model year. Are you certain your 2003 doesn't already have the Akebonos up front? I've never seen a 2003 with Teves.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #5 of 15 Old 06-17-2019, 02:56 PM
97Mule
97Mule's Avatar
What i mean is IF u dont order from them. I think i got mine from 4wheel parts ( pads, calipers, rotors) #KC2150-36 Front and back (includes AKEBONO CALIPER)
# KC2149-36 Front only ( pads, calipers, rotors)
#KC2151-36 Rear only ( pads, calipers, rotors)
Also @Kolak can get u set up!!!
In fact i don't think they even sell the teves calipers since the akebono is a upgrade.
Kolak likes this.
97Mule is offline
post #6 of 15 Old 06-17-2019, 11:27 PM
Uniblurb
Uniblurb's Avatar
Yeah, as already mentioned below is the brake TSB on WJ's manufactured on and after May 11, 2002 came with Akebono calipers.
http://www.wjjeeps.com/brakes.htm
Those are the S-4826 Akebono Power-stop calipers in that kit and I installed them on my 04 4.7 last year as can be seen in the below photos. While they're sold as a set the 4826 is the right front while the 4827 is the left front.
https://www.jeepforum.com/forum/f310...ipers-4289897/
I went a little different route and loaded the calipers myself with Wagner ceramic pads while going with Centric front rotors. Good luck.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
post #7 of 15 Old 06-18-2019, 09:32 AM Thread Starter
torchd
2003 WJ
I am almost positive I still have the old Teeves style calipers. My Jeep is sold a 2003 Model, however, I remember seeing a sticker that said 5/2002.
Thank you! I'll look into other websites to see if they're cheaper!
EDIT: Looked at QuadraTrack and 4Wheel Parts, much more expensive than Rock Auto!
I just came across your thread from last year regarding you upgrading to the PowerStops calipers.
Just because there is a TSB, doesn't mean my Jeep was done. Would any dealership still honor this TSB today? Providing I still had the old Teeves?
2002 Trans Am
torchd is offline
post #8 of 15 Old 06-18-2019, 11:00 AM
97Mule
97Mule's Avatar
Way to many yrs have passed to honor that tsb.
97Mule is offline
post #9 of 15 Old 06-18-2019, 01:26 PM
Kolak
Vendor
Kolak's Avatar
Do your front calipers have a large coat-hanger style pad retaining wire that goes across them?
or
Kolak is offline
post #10 of 15 Old 06-18-2019, 02:37 PM Thread Starter
torchd
2003 WJ
Yeah, I figured as much LOL.
That's what I was trying to remember today... I'm almost positive I have that going across the front of the front pads. I'll have to go outside and look once I leave work.
I cannot remember, will the retaiing wire be on the outside or inside of the caliper?
2002 Trans Am
torchd is offline
post #11 of 15 Old 06-18-2019, 03:16 PM
97Mule
97Mule's Avatar
Outside. Should be able to see very easy!
97Mule is offline
post #12 of 15 Old 06-19-2019, 09:23 AM Thread Starter
torchd
2003 WJ
you sir are correct!
My Jeep, per the sticker on the drivers side front door, Jeep has a date of 8/2002.
Also, I have the Akebono calipers.
So this is why I want to replace ALL calipers. A normal rotor's surface is flat and pretty uniform. I did my brakes 8/2016 with the PowerStop cross drilled and slotted rotors. I noticed last month, on all 4 corners the rotors in 2 different spots, going around the whole face there are grooves, maybe 1/4'' wide. That tells me that something is sticking or my outside pads are wearing fast and uneven?
2002 Trans Am
torchd is offline
post #13 of 15 Old 06-20-2019, 06:56 PM Thread Starter
torchd
2003 WJ
Here are pics of rotors
2002 Trans Am
torchd is offline
post #14 of 15 Old 06-21-2019, 02:10 AM
Kolak
Vendor
Kolak's Avatar
Those look like Akebono to me. I don't see the wire and I think I can see the caliper pad clips that Akebono uses. Look at the first pic here:
https://www.jeepforum.com/forum/f310...id-me-1068062/
or
Kolak is offline
post #15 of 15 Old 06-24-2019, 08:20 AM Thread Starter
torchd
2003 WJ
Yes, these are indeed Akebono calipers. I think I was confusing the rear calipers with the wire for the fronts.
I am still trying to figure out why the fronts have those 2 wear spots on the rotor?
2002 Trans Am
torchd is offline
