Right Rear Window Only Works From That Door - JeepForum.com
post #1 of 6 Old 02-22-2019, 10:22 PM Thread Starter
smsullivan11
So have a problem with my new to me 04 GC Special Edition. The right rear window only works from that door control and will not work from my driver's side door. That being said the driver's door "master" control does lock and unlock all doors and also works for all other windows. I was thinking first place to start would be to replace the master control on the driver's door, but thought I would ask the community before spending the $30 on a replacement.
smsullivan11 is offline
post #2 of 6 Old 02-22-2019, 10:57 PM
2oldjeeps
check wire diagram in haynes book. usually wires
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #3 of 6 Old 02-23-2019, 01:06 AM
86cj74.2L
86cj74.2L's Avatar
Somewhere on here I have the wiring posted for the windows and locks. If I remember correctly the rear door window got powered from its front door module on its side of the vehicle. Thatís why your rear window works locally but not remotely from the drivers door. It could be a bad switch for that window on the drivers door module.
Look for my drawings and Iíll try and dig them up again.
Sent from my iPhone using Tapatalk
86cj74.2L is offline
post #4 of 6 Old 02-23-2019, 09:41 AM
plimbob
I just had the same kind of situation. Pull the wiring boot in the drivers side door and take a look at the wiring, I found a broken wire in that loom.
plimbob is offline
post #5 of 6 Old 03-14-2019, 07:55 PM
niteowls59
I had same problem. Broken wire in boot on passenger side front door. Also fixed heated mirror on that side. Check wires on both doors.
niteowls59 is offline
post #6 of 6 Old 03-15-2019, 08:10 AM
jserna
1987 YJ Wrangler
Yep check those wires!!!
jserna is offline
Rear Door Flare Extension & Qtr Panel Wheel Flare Installation BCJr91 Grand Cherokee General Discussion 2 08-22-2018 12:38 PM
Lefr rear window goes down but not up! bagelluvr WJ Grand Cherokee Forum 2 05-31-2018 12:57 PM
CJ7 Soft top - The passenger side rear window keeps coming out of the rail HKlassen Jeep CJ Forum 4 04-30-2018 08:41 AM
McGuyver a Rear Window Defroster tab? robchristianson Cheap Tricks & Fixes 2 01-24-2018 05:32 PM
CrankyGypsy's 2004 Rubicon CrankyGypsy Jeep Builds 33 05-14-2017 09:03 PM
