Right Rear (Passenger Side) Disk Brake smoking. 1999 Limited - JeepForum.com
 2Likes
post #1 of 17 Old 06-13-2021, 05:18 PM Thread Starter
caliskier
Hi all,
I have a 1999 Limited and I am 99% sure I updated it to the better ones, the Akebono. I have a note in my log i replaced this Caliper in January of 2020. What I have going on right now is my wife went and drove it, came home ran in the house and said the car stunk. I went out and the Right Rear brake had smoke wafting over the top of the car.
I am guessing its locked, but I don't know. How do I fix this? Thoughts?
caliskier is offline
post #2 of 17 Old 06-13-2021, 07:19 PM
blueseasons1
My understanding is they dont make Akebono for the rears. I remember reading there is no difference in the construction/design between Akebono and Teves for the rears. In any event. I'd replace it. Buy the time you remove it and take it apart and clean it you could just swap in a new one and be on your way.
Joey Bagadonuts likes this.
blueseasons1 is offline
post #3 of 17 Old 06-13-2021, 07:41 PM
CJREX
CJREX's Avatar
I'd replace both calipers. JMO but I'd never do only one side of brakes.
Bigrigr likes this.
2004 GC Overland 4.7 HO
Powerful Wanderer (wife named it after driving it)
265/70/17 MT, 2" BDS lift
CJREX is offline
post #4 of 17 Old 06-13-2021, 07:43 PM
helijeeper
helijeeper's Avatar
I chased this problem and tried all the cheaper other fixes (slide pins, lines, cleaning) before I broke down and finally did all new calipers, discs and pads on both sides. At a minimum if you havenít smoked the pads and disc already I would say a caliper would do it.
Sent from my spyPhone using Tapatalk
Fly Low, Take Chances
04 Grand Cherokee 4.0L Laredo
94 Cherokee 4.0HO Bone Stock
helijeeper is offline
post #5 of 17 Old 06-14-2021, 01:11 PM
Delta0
Originally Posted by caliskier View Post
Hi all,
Did you replace the brake hose when you replaced the caliper?
If not is might be causing your problem.
Try loosing the outboard connection to the hose, if brake juice squirts out the hose is likely the problem.
It's also possible to damage a non-flexible pipe.
You can check for pipe damage just by looking.
If little juice comes out when you open the relevant bleed nipple, and still can't prize the caliper open, it looks like your 18 month old caliper has gone a knacker I'm afraid.
How long is the warranty?
Delta0 is offline
post #6 of 17 Old 06-14-2021, 02:22 PM
Ozzel99WJ
Definitely sounds like a stuck caliper but also worth noting it could be a leaky wheel bearing axle seal dripping onto the e-brake shoes (usually won't be that smokey though). When you pull the caliper double check those so you don't have to do it all again.
-JC
Ozzel99WJ is offline
post #7 of 17 Old 06-14-2021, 05:59 PM Thread Starter
caliskier
Thanks for that, was not sure...
Originally Posted by helijeeper View Post
I chased this problem and tried all the cheaper other fixes (slide pins, lines, cleaning) before I broke down and finally did all new calipers, discs and pads on both sides. At a minimum if you haven’t smoked the pads and disc already I would say a caliper would do it.
Thanks Delta, when I remove it I will check into it and see if it squirts when I take it off.
Thanks to all 4 of you, same recommendation to replace it, maybe both. I believe I got it from NAPA and they said it's a lifetime warranty.
You know I don't really care about the lifetime warranty, I care about not having to do it again.
-JC
Thanks JC, It is definitely brake smell so I am in agreement it the caliper is stuck.
post #8 of 17 Old 06-15-2021, 01:24 AM
Delta0
Thanks Ozzel
How about replacing the hose while you are down and dirty?
Delta0 is offline
post #9 of 17 Old 06-15-2021, 05:17 AM
Bigrigr
Bigrigr's Avatar
Any sign of fluid leaking at this rear wheel? Its pretty common to have an axle seal leak gear lube onto your brakes. It starts by soaking the park brake shoes, then if left unchecked it works its way onto the rear service brakes...Gear lube stinks something terrible when its burned off by the brakes getting hot with use....
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #10 of 17 Old 06-16-2021, 08:28 PM Thread Starter
caliskier
Thanks Ozzel
I probably should its a 22 year old car
BIGRIGR! The man, you have helped me so much!! No sign of fluid leaking and when I lifted up the car tonight the wheel began to move, as in its not locked up. Is is possible this was a fluke thing? I think I will leave it alone and see if it happens again.
Edit: Just drove it around the block (5 miles), no smell, no smoke.
post #11 of 17 Old 06-17-2021, 12:04 AM
Ozzel99WJ
Maybe she had the ebrake on by accident? That would make the brake shoes smoke all right! Glad it went away, hopefully doesnt come back.
post #12 of 17 Old 06-17-2021, 07:37 PM Thread Starter
caliskier
Yeah I asked her that, she said she didn't, but who knows. Drove it two additional 8 mile trips with ~10 breaking opportunities each. No issue. My trips to work are short so I will keep watching it.
post #13 of 17 Old 06-18-2021, 08:31 AM
leadsled jeep
leadsled jeep's Avatar
You’re getting great advice here. Can’t wait to hear your fluid flow when pedal is pressed and bleed nipple is loosened.
After that it’s likely piston seal or slides binding.
I just chased my tail back and forth when I did replaced caliper (front akebono) as the pad was draggin’ and smokin’ but don’t check the pins for sufficient grease.
Took it apart and greased pins (yeah my bad I didn’t grease at caliper change a while back) only to discover I was again smoking pads. So I burned out piston seals again.
New caliper (I didn’t want to rebuild as it was still under OReillys warrantee) and finally got it done right.
When you keep messing up, just keep at it and eventually you’ll learn around your ignorance in whatever area you messed up. Best was to fix ignorance is education and sometimes the best education is the school of hard knocks!
Lumps on my head prove I’ve learned there!!
'02 HO 235k ml. BDS, tubular arms, Addco sways. 245-70-17. Stock engine/tranny. Amsoil. W1CCW.
leadsled jeep is offline
post #14 of 17 Old 06-19-2021, 10:59 AM Thread Starter
caliskier
Originally Posted by leadsled jeep View Post
Youíre getting great advice here. Canít wait to hear your fluid flow when pedal is pressed and bleed nipple is loosened.
After that itís likely piston seal or slides binding.
I just chased my tail back and forth when I did replaced caliper (front akebono) as the pad was dragginí and smokiní but donít check the pins for sufficient grease.
Took it apart and greased pins (yeah my bad I didnít grease at caliper change a while back) only to discover I was again smoking pads. So I burned out piston seals again.
New caliper (I didnít want to rebuild as it was still under OReillys warrantee) and finally got it done right.
When you keep messing up, just keep at it and eventually youíll learn around your ignorance in whatever area you messed up. Best was to fix ignorance is education and sometimes the best education is the school of hard knocks!
Lumps on my head prove Iíve learned there!!
Spot on! When you pay someone else to do it you miss the education and you miss the money you could have invested.
post #15 of 17 Old 07-05-2021, 03:46 PM Thread Starter
caliskier
Ok so it did it again so I replaced the caliper, looks like I now need to replace the rotors and pads. any recommendations?
