Riddle me this...plugs, coils, and fuel mileage - JeepForum.com
 4Likes
  • 2 Post By GmanWJ
  • 1 Post By WJ60
  • 1 Post By soler300
post #1 of 14 Old 07-21-2021, 06:31 PM Thread Starter
soler300
2004 GC 4.7...was getting 18.5 mpg. Not terrible, but with the dinky tank size, range is not so great. Wanted to see if I could squeeze a little more out of her. Changed plugs and coils. Now getting 15-16.5 mpg. What the dang heck?!
soler300 is offline
post #2 of 14 Old 07-22-2021, 10:17 AM
Bigrigr
Bigrigr's Avatar
How far have you driven since the plug change? It may take a few hundred miles to get the PCM to adjust to the new parts for accurate fuel mileage.
If your getting 18.5 mpg's then leave it alone...It dont get better than that...
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #3 of 14 Old 07-22-2021, 10:39 AM
jtec
jtec's Avatar
2014 JK Wrangler
lets start simole-
What plugs did you use?
How did old plugs look- wet, dry, black, tan?
Any codes (scanner)?
Is engine reaching correct temp?
DO you have a scanner? lots we can look at then.
jtec is offline
post #4 of 14 Old 07-23-2021, 07:46 AM Thread Starter
soler300
Plugs looked okay. Like they needed to be replaced, but not horrible. It's been several months. I thought the same thing about it taking some time to work itself out, but now I'm done waiting. Going to look at what plugs I installed. And going to put old coils back in and then start troubleshooting from there. BTW, since we're on the subject, what's the correct plugs? Irridium, platinum, or what? I did research when I did the plug change, but it's been almost a year.
Thanks!
soler300 is offline
post #5 of 14 Old 07-23-2021, 07:58 AM
GmanWJ
GmanWJ's Avatar
I would like to know if you come up with anything here.
Once upon a time, I got 19-20 mpg. Normal has been around 17. Lately I think I am closer to 15, and when towing it was 12. Now I have bigger tires and the last time I towed I was hitting 10, and even dipped under 8 when my right foot was too heavy.
If replacing anything can improve this (injectors, coils, plugs, sensors), I would be all in. At $5/gallon and 10 mpg ... well that's $0.50/mile isn't it?
Wyo and msavic6 like this.
2.5" OME HD & Bilsteins
Dual Batteries
Aux Trailer Hookups (4awg charging & backup cam)
GmanWJ is offline
post #6 of 14 Old 07-23-2021, 09:12 AM
WJ60
WJ60's Avatar
From WJJeeps.com:
4.7 Plug: SPRC12MCC4 Gap: 0.040
The standard 4.7L engine uses copper core ground electrode spark plugs, they must be replaced with the same type/number spark plug as the original. If another spark plug is substituted, pre-ignition will result.
Bigrigr likes this.
WJ60 is offline
post #7 of 14 Old 07-23-2021, 11:34 AM
jtec
jtec's Avatar
2014 JK Wrangler
4.7L vin N RC12MCC4 (.040 in.)
4.7L vin J RC7PYCB4 (.040 in.)
04 OEM manual.
jtec is offline
post #8 of 14 Old 07-24-2021, 07:14 AM
Darnice
I would be looking at maybe a seized brake caliper. It may be dragging a bit. After a drive check your rim near the center if one is warmer than the others. Don't touch the disc unless you want a burnt finger
Darnice is offline
post #9 of 14 Old 07-24-2021, 07:35 AM
cDee63
cDee63's Avatar
Send me your old parts please, if they are getting you 18.5 I'll install them on mine in a heartbeat. I can get that on the highway with the cruise on 70, but around town I'm hitting around 14.4 according to the onboard MPG counter. I do feel it is optimistic however due to the speedo being off from the tire size. I highly doubt going from a 29" tire to a 32.5" tire increased my fuel mileage by almost 1.5 mpg's.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is online now
post #10 of 14 Old 07-25-2021, 08:55 AM Thread Starter
soler300
Thanks for the replies!
Brakes...I put new brakes on several months before doing plugs. No issues, but I'll definitely check them out.
I'm gonna check the plugs I installed against the part numbers posted
I'll let you know how it goes.
soler300 is offline
post #11 of 14 Old 07-26-2021, 08:18 AM
Double E
Double E's Avatar
Pull the TB off of the intake, clean it. Pull the IAC, clean it. You'll see why once you get in there. Swap out your fuel filter too and toss in a bottle of Techron.
Make sure your alignment is good, tire pressures are set right and try to drive so that you keep the RPMs at 2200 or less while accelerating. You'll easily reach 70MPH at 2200 RPM.
The fuel tank is a little over 20 gallons. That's actually a decent size for a mid-size SUV.
"We have it totally under control. Itís one person coming in from China. We have it under control. Itís going to be just fine." ~D. Trump, Jan 22, 2020.
Double E is offline
post #12 of 14 Old 07-27-2021, 07:22 AM
leadsled jeep
leadsled jeep's Avatar
I hope you aren’t counting on the digital EVIC to provide accurate mpg. It’s horribly inaccurate and inconsistent. Miles driven per gallons pumped in is the only way to get data you can trust. I posted a long write up on this years ago with mpg over long interstate travel with various octanes. It’s here somewhere and may be helpful for you to refer to.
'02 HO 235k ml. BDS, tubular arms, Addco sways. 245-70-17. Amsoil. W1CCW WRKi761
leadsled jeep is offline
post #13 of 14 Old 07-27-2021, 08:11 AM
xcaliber81
xcaliber81's Avatar
My evic shows 17 liters per 100. When I hand calculate its getting 13.6 liters per 100. Just under 18 mpg but im mostly short trips and tbh I'm not trying for the best I just drive it like I normally do.
xcaliber81 is online now
post #14 of 14 Old 07-27-2021, 10:15 AM Thread Starter
soler300
Originally Posted by leadsled jeep View Post
I hope you arenít counting on the digital EVIC to provide accurate mpg. Itís horribly inaccurate and inconsistent. Miles driven per gallons pumped in is the only way to get data you can trust. I posted a long write up on this years ago with mpg over long interstate travel with various octanes. Itís here somewhere and may be helpful for you to refer to.
I always hand calculate. It's the only way.
leadsled jeep likes this.
soler300 is offline
