Replacing both L & R Front Brake Calipers on 99 WJ - Can I just bleed front brakes? - JeepForum.com
post #1 of 7 Old 03-01-2020, 10:11 AM Thread Starter
caliskier
That is the question. I have the 99 WJ quadradrive and I am replacing the calipers. I am wondering if I need to bleed all four wheels or if I can do just the fronts? I bled them all 6 weeks ago so the fluid is new. I understand when you bleed 4 its rear right then rear left, then front right and front left. I am assuming the fronts are on a different line from the master cylinder and thus the question, can I just bleed the fronts?
Just came out of the mountains with terrible vibration in the front while braking so I am upgrading to the akebono in the front (could not get to it before my trip).
caliskier is offline
post #2 of 7 Old 03-01-2020, 12:35 PM
2oldjeeps
i did just the ones i changed, even with abs. my wj pedal is softer than my xj"s but it stops good and pedal is not low.
thinking i gravity bled too. worked for me. i use a cement block as a helper when bleeding.
oh,abs works great too...
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #3 of 7 Old 03-01-2020, 04:06 PM
Bigrigr
Bigrigr's Avatar
Just bleed the front, it wont matter which one you start with. Just pick one and bleed completely, then switch to the other side and do the same. Double check you pedal, if you need to go again, do another round until you get a hard pedal.
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #4 of 7 Old 03-01-2020, 05:34 PM Thread Starter
caliskier
Thanks BigRigr and Jeeps, appreciate the help.
post #5 of 7 Old 03-02-2020, 08:14 AM
mxer201
While replacing the calipers, I would suggest replacing both brake hoses if you haven’t replaced them already. I’ve experienced the hoses collapsing internally and not allowing fluid to return to the master cylinder. The end result was the caliper not releasing.
mxer201 is offline
post #6 of 7 Old 03-02-2020, 09:46 AM
frankjc
Only need to bleed the ones that were replaced, the front and rear are not connected.
frankjc is offline
post #7 of 7 Old 03-02-2020, 07:33 PM Thread Starter
caliskier
Thanks again folks.
