Replacing a blown door speaker - JeepForum.com
post #1 of 9 Old 09-28-2012, 09:53 AM Thread Starter
gcsmorgan
Question Replacing a blown door speaker
I searched through some posts on here and saw one person that said if you replace the base speaker with an aftermarket one it can damage the radio? I'm looking to replace the rear passenger speaker, so it should be a simple swap/plug-n-play right? Or is it a little more involved?
Also, any suggestions on 6.5 inch door speakers?
2002 Jeep Grand Cherokee Laredo Sport | 4.0L I6 | 2WD | 225-75-R16 BFG Radial Long Trail T/A
gcsmorgan is offline
post #2 of 9 Old 09-28-2012, 10:53 AM
Schlotzky
2007 XK Commander
The rears are full range so there is no issue there. I had heard the stock stuff is 2ohm but my electrical tester told my my aftermarket 4 ohm speakers had exactly the same resistance as the stock ones. I personally like Pioneer's stuff for the lower end of the price spectrum, with rockford fosgate coming next at a slightly higher price point. Realize that if you don't want to drill holes in your door panel, you'll need to buy a speaker adapter from crutchfield or bestbuy or something. Other than that, it's straight forward besides a bit of basic soldering or crimping of new connectors after you cut off the factory connector (or buy an adapter for that as well, which allows for zero modification). Check out WJ Jeeps for wiring diagrams for your year.
Schlotzky is offline
post #3 of 9 Old 09-28-2012, 12:31 PM
snowman91
2003 WJ
It wouldn't be plug and play for after market speakers. Just cut the connector off and crimp the positive and negative to the speakers. Never heard about damaging the stock stereo with after market speakers. The rear is 6.5 speakers
snowman91 is offline
post #4 of 9 Old 09-28-2012, 02:37 PM Thread Starter
gcsmorgan
Thanks! After I posted the thread I thought about looking at wjjeeps.com. I understand that the rears are full range, but could I put in a 6x5 woofer in the rear door speakers to add more bass? The front door speakers already produce a decent amount of bass, and if I doubled it... I think that would be sufficient (instead of buying a separate 10" Subwoofer).
post #5 of 9 Old 09-28-2012, 02:45 PM Thread Starter
gcsmorgan
OR, here's a thought- could I get a separate subwoofer, something small (like 8"), and wire that to my existing infinity amplifier?
post #6 of 9 Old 09-28-2012, 03:35 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
no.
the infinity amplifier is designed only for exactly what the vehicle came with in stock configuration.
ratmonkey is offline
post #7 of 9 Old 09-28-2012, 03:48 PM Thread Starter
gcsmorgan
Originally Posted by ratmonkey View Post
no.
I see. I want to find something relatively inexpensive ($50-100 range) to add to my audio system to give me some more bass.
Would this: http://tiny.cc/nl5clw plus a small amp: http://tiny.cc/be5clw
or this: http://tiny.cc/2b5clw
be good?
post #8 of 9 Old 09-28-2012, 03:55 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
For less than that second subwoofer you could get a sub and build your own box whatever shape you wanted. That way you could build it to fit somewhere nicely.
In the garage: M1 4bbl
McCloudsZJ is offline
post #9 of 9 Old 09-29-2012, 12:04 PM Thread Starter
gcsmorgan
I don't have the materials or the tools to build a custom box. I wish I did!
Door speaker? jeep04 WJ Grand Cherokee Forum 29 01-06-2012 03:58 PM
Front driver side door speaker works occaisionally justn WJ Grand Cherokee Forum 4 11-19-2011 06:22 PM
Blew Rear Door Speaker Madmike4790 WJ Grand Cherokee Forum 4 07-19-2011 05:32 PM
Replacing Door Glass Help modell WJ Grand Cherokee Forum 2 10-25-2010 08:46 AM
6.5" speaker in Front Door 6x9 location? 99 wj cbas84 WJ Grand Cherokee Forum 2 08-08-2010 03:03 PM
