Replacing battery terminals with pics - JeepForum.com
post #1 of 11 Old 09-06-2010, 12:48 PM Thread Starter
metalhead
2011 WK
I replaced my battery terminals today. As you can see in the first picture they were bad especially the neg terminal. I bought a set of the clamp on terminals but be careful I bought ones that were too big and it would not hold the wires tight. In the pictures you will see the tool I used to cut the wires. I also used red loctite on the bolts that hold the wire in place and tightened it as tight as I could and wrapped some electrical tape around the wires. So far so good. Its a lot easier and cheaper than replacing the whole harness.
metalhead is offline
post #2 of 11 Old 09-06-2010, 12:53 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Looks good! I had to do the same on my ZJ. I used marine-style terminals with a wing-nut on a vertical stud and large copper crimp-on lugs for the wires. It makes it easier down the road if you do any custom wiring work when you have a bolt (like you do) or a stud (like I do).
~Richard
billzcat1 is offline
post #3 of 11 Old 09-06-2010, 05:50 PM
tennesseewj
Looks pretty good. Next time, though, use some shrink tube on it instead of electrical tape and it will look even cleaner
2004 4.0 Selec-Trac
BB->Black Diamonds->General Grabbers
Originally Posted by Sporer65 View Post
You need to learn, there are 3 things that all JF members must like beside Jeeps:
(1) Guns (2) Women (3) Bacon
Originally Posted by GraKee99 View Post
I was bored so I forded the river. No oxen were lost.
tennesseewj is offline
post #4 of 11 Old 09-06-2010, 05:58 PM Thread Starter
metalhead
2011 WK
Yea I thought of that but I didn't have any on hand and didn't have time to get any.
post #5 of 11 Old 09-06-2010, 06:06 PM
steelstr45
nice! Just wondering, how hard would it be to replace the cables instead of the ends? I know on Tauruses it's pretty easy. Never thought about it on a GC though.
steelstr45 is offline
post #6 of 11 Old 09-06-2010, 07:49 PM
austinaubinoe
What tool did you use to crimp them, could you just beat the lugs with a hammer? just solder them on? can you fit both factory cables into one lug on each side?
austinaubinoe is offline
post #7 of 11 Old 09-06-2010, 10:42 PM
billzcat1
2003 WJ
I fit both cables into one lug per side. I think they were a 6-gauge copper lug I used. I actually used vice grips to crimp them. Right at the point that vice grips "clamp down" they put a surprising amount of force through the jaws. Crimp, tighten 1/2 turn, crimp, tighten, etc. I crimped down a little at a time until it was crimped as tight as it would go. This was one of the first repairs I did on the ZJ and it has held up fine ever since.
~Richard
post #8 of 11 Old 02-05-2014, 08:32 AM
Frasi
Bad battery cable lug
Thanks, looks great.
I just had the same problem, the lug on the positive cable came off from the cable, due to corrosion, do you know where can i find a replacement lug the hold the 2 cables (the positive cable on my grand cherokee 2000 LE haa 2 cables that go into the lug)
Thanks
Frasi is offline
post #9 of 11 Old 02-05-2014, 08:43 AM
billzcat1
2003 WJ
Any local auto parts store will have what you need over in the generic battery cable/battery terminal section. O'Reilly, Napa, and Autozone in my area all have an excellent selection of parts like this - I'd expect the same for you.
~Richard
post #10 of 11 Old 02-05-2014, 08:51 AM
Frasi
Thanks Richard.
There is a Napa store 1 mile from my house, i will walk and get one, will bring the old one with me to compare.
Frasi is offline
post #11 of 11 Old 02-05-2014, 10:16 AM
dcorn
dcorn's Avatar
I bought one of these to crimp my battery cables into the lugs. Worked perfectly, just a little awkward to set up since the battery cables aren't very long.
http://www.amazon.com/NOCO-D800-Hamm...=pd_sim_auto_4
2014 Jeep Grand Cherokee Summit
dcorn is offline
Pulled Trans Pan - 142K miles on original fluid! Pics! Pics! Pics! Soft 8 WJ Grand Cherokee Forum 11 02-02-2009 05:10 PM
'02 WJ Battery? ThorSonic WJ Grand Cherokee Forum 6 08-11-2007 03:50 PM
Battery fs_wheel WJ Grand Cherokee Forum 2 03-08-2004 02:29 PM
newbie wants second battery in 02 GC 19d WJ Grand Cherokee Forum 1 01-22-2004 06:54 AM
issues replacing battery ccyoder WJ Grand Cherokee Forum 2 10-17-2003 03:13 PM
