Repair options for rear upper spring perch? - JeepForum.com
post #1 of 6 Old 11-10-2019, 04:00 AM Thread Starter
AVR2
The tower part of the rear upper spring perch has rotted away on a friend's WJ. Are there any bolt-in aftermarket repair options, or is it a case of fabricating something or trying to find a decent one in a junkyard? The Mopar part (#2 in the diagram) now seems to be discontinued.
AVR2 is offline
post #2 of 6 Old 11-10-2019, 04:51 PM
Ravenbar
Shouldn't be that hard to find a donor. Been a while since I've had my rear suspension apart, but that diagram doesn't look right for a WJ. I don't recall parts 3 or 4.
I would be concerned how much more rot is hiding on your friends Jeep. Worst area for rot is the lower control arm mounts on the body. the frame rail likes to rot out there and as far as I know, there is no repair parts for that.
Project Thumper:
KD2QQF
Member of Fourth Coast Jeeps
Ravenbar is offline
post #3 of 6 Old 11-11-2019, 07:03 AM
CarlJH
2003 WJ
X2 on the rust concerns, that's a thick piece of metal to have rotted away, there's much thinner body panels it attaches to I'd be looking at.
CarlJH is offline
post #4 of 6 Old 11-12-2019, 03:52 PM Thread Starter
AVR2
It's straight from the WJ parts catalog. I think the parts you query are for Up Country suspension only - #3 is listed as "Spacer, jounce bumper". My WJ doesn't have UC, and hence doesn't have those parts.
Thanks for the heads-up on the rust, I'll let him know.
AVR2 is offline
post #5 of 6 Old 11-12-2019, 07:58 PM
xcaliber81
xcaliber81's Avatar
I have upcountry now I don't remember a bolt but there is an isolator the spring sits in.
http://www.wjjeeps.com/upcountry.htm
xcaliber81 is offline
post #6 of 6 Old 11-15-2019, 04:39 PM
Ravenbar
That's what I recall. Upper perch, isolator, spring, isolator, lower perch, with the bump stop fitting into a sleeve on on perch, and the other having a solid surface for it to hit.
Project Thumper:
KD2QQF
Ravenbar is offline
