Remove fuel rail to change one injector? - JeepForum.com
post #1 of 4 Old 03-14-2019, 07:59 PM Thread Starter
Photoweborama
1936 CJ2A
Well my re insulating injector #3 has not seemed to fix the problem.
So do I have to remove the entire fuel rail to change one injector?
Sent from my iPad using Tapatalk
Photoweborama is offline
post #2 of 4 Old 03-15-2019, 08:18 AM
mikeundi
Not sure if you've got the I6 or V8, but when I changed over to 4-hole injectors on my 4.0L, I didn't bother to take the rail off, just popped 'em out and back in. Just make sure you relief the fuel pressure before you begin!
mikeundi is offline
post #3 of 4 Old 03-15-2019, 08:59 AM Thread Starter
Photoweborama
1936 CJ2A
Got the 4.0 I 6. So it is possible to get them off without taking the rail off..
post #4 of 4 Old 03-15-2019, 09:12 AM
jtec
2014 JK Wrangler
insulating, replacing inj - whats the issue?
Same inj as others - if others are 1 hole use same.
jtec is offline
Is this a fuel injector connector? A rabbit ate it... DOH! Roccobagadonuts ZJ Grand Cherokee Forum 6 03-10-2019 03:44 PM
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
Adjustable FPR and cross flow fuel rail on the cheap Cobra Jeep YJ Wrangler Technical Forum 6 12-30-2018 07:22 AM
Help, my wife put gas in our CRD by mistake Zroe89 WK Grand Cherokee & XK Commander Forum 26 11-09-2018 04:34 PM
WK fuel tank and unibody frame rail height/dimensions? jeepradiator99 WK Grand Cherokee & XK Commander Forum 0 10-26-2018 02:14 PM
