Regarding fuel tank skid guards - JeepForum.com
 4Likes
post #1 of 17 Old 10-16-2021, 11:00 AM Thread Starter
WJ60
WJ60's Avatar
There's nothing wrong with mine (yet). I never go off road, so if it ever rusted out, couldn't I just remove it and go without? $300+ seems like a lot for a new one.
'77 Chevy C10 pickup
'01 WJ 60th Anniversary Edition
'13 Dodge Dart Rallye
WJ60 is offline
post #2 of 17 Old 10-16-2021, 11:46 AM
snowbuggy
If yours isn't rusted yet then it should be good for another 10 years at least. When it's rusted and they have you over a barrel then you will pay the $300.
snowbuggy is offline
post #3 of 17 Old 10-16-2021, 12:14 PM
Soem0
Soem0's Avatar
That skid guard is what is holding your tank in place
Soem0 is offline
post #4 of 17 Old 10-16-2021, 01:58 PM
frankjc
If the skid plate falls off, your gas tank goes with it.
Ive seen them in the $150 range, aftermarket.
sdg3205 likes this.
frankjc is offline
post #5 of 17 Old 10-16-2021, 11:18 PM
sdg3205
sdg3205's Avatar
Part outs. I got a mint skid for $40.
One of those parts thatís good to pick up if itís comes available at a good price.
snowbuggy likes this.
sdg3205 is offline
post #6 of 17 Old 10-17-2021, 11:03 AM Thread Starter
WJ60
WJ60's Avatar
Is the tank made of metal? If it is I'd consider making some metal straps to secure it, which is what most cars and trucks have.
WJ60 is offline
post #7 of 17 Old 10-17-2021, 12:07 PM
cDee63
cDee63's Avatar
They also made 2 different ones, the earlier ones were much heavier and thicker material than the later ones. I forgot the change year, I believe 02 or 03.
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #8 of 17 Old 10-17-2021, 06:01 PM
DonL3
There are two types. One is a brushguard, thin metal. The other is an actual fuel tank skidplate, much thicker metal. If you bang on it with a small hammer or screwdriver, the brushguard with thump, but the skidplate will almost "Ring" because of the almost triple thick metal.
The Fuel tank skidplate is basically interchangeable 99-04. And yes they had the fuel tank skidplates on the 2004 Overland model. It was optional on other models.
cDee63 and smokeythecat like this.
DonL3 is offline
post #9 of 17 Old 10-18-2021, 07:40 AM
Mr. Bitey
Mopar Nut
Mr. Bitey's Avatar
I have questions here too, as mine is probably not long on life. I think there is also 2 tank straps under the skid plate. Couldn't a guy drop the assy, ditch the plate, and just hang the tank on 2 new straps?
2004 WJ 4.7 N, daily driver
1967 Jeep J100 panel truck (a-rusted development)
1970 'Cuda, 340 4bbl (10.952et @ 123mph)
1972 Dart Swinger, Gen III 6.4l Hemi (11.223 @ 113mph)
1974 AMC Gremlin X, 440 6bbl (sold)
1975 Jeep Cherokee Sport 2-door (in progress)
Mr. Bitey is offline
post #10 of 17 Old 10-18-2021, 08:25 AM
Soem0
Soem0's Avatar
The straps attach and secure the tank to the skid.
Soem0 is offline
post #11 of 17 Old 10-18-2021, 09:04 AM
Mr. Bitey
Mopar Nut
Mr. Bitey's Avatar
Bummer. When the time comes, I'll have to study it a bit. There's gotta be a way to customize that - I've really no use for the skid plate myself.
post #12 of 17 Old 10-18-2021, 09:15 AM Thread Starter
WJ60
WJ60's Avatar
I agree with you Mr Bitey. There has to be a way to create heavy straps that will hold that tank in place.
WJ60 is offline
post #13 of 17 Old 10-18-2021, 09:21 AM
Mr. Bitey
Mopar Nut
Mr. Bitey's Avatar
I have a set of new-in-the-box straps for a 1996 Dodge B2500. Surely I can craft something out of them. Probably a spring project. The tank isn't ready to fall out just yet, but will definitely be close after another salty Wisconsin winter....
post #14 of 17 Old 10-20-2021, 10:16 AM
cajunzman
It'll be all good until you catch them fuel lines on a cardboard box. Not to mention these already had the pinto problem of being a bomb when rear ended not sure I'd want to remove any sort of protection that actually was in place especially on the dad bods.
cajunzman is offline
post #15 of 17 Old 10-20-2021, 10:34 AM
Mr. Bitey
Mopar Nut
Mr. Bitey's Avatar
Not like the rotten skid plate on most of the remaining WJs are doing anything for structural integrity. And I could be wrong, but I am pretty sure the exploding WJ's had to do with after market hitches, and they were ripping through perfectly sound skid plates. That was supposed to be solved with a dealer installed hitch. The hitch was designed to provide extra protection for the fuel tank.
