Rear view camera location - JeepForum.com
 6Likes
  • 3 Post By Oktavius
  • 1 Post By SD Overland
  • 1 Post By 68Charger
  • 1 Post By wjkeith
post #1 of 13 Old 01-17-2020, 09:34 AM Thread Starter
wjkeith
wjkeith's Avatar
Iím thinking of installing a rear view camera now that I have a stereo that supports one. Deciding between these two locations. Can anyone offer some first hand experience? Will use a Natika camera.
0C6948FE-D90E-415A-8097-DE5EC231CC45.jpg   4DA6D137-B342-471B-86F0-2DE923AD5E5D.jpg
wjkeith is offline
post #2 of 13 Old 01-17-2020, 12:22 PM
Oktavius
I mounted mine above the license plate. Took the panel off which houses to the license plate lamps to help route the cables into the rear hatch. Then routed the cables around the rear window, through to the boot to the body, and then to the rear passenger's side where the CD changer used to be. Reason I went to the passenger's side is that I had removed the CD changer but still had the wiring. I reused the CD changer wires so that way I didn't have to run wires all the way from the back to the head unit.
ShinyWJ, wjkeith and WJ60 like this.
Oktavius is offline
post #3 of 13 Old 01-17-2020, 12:57 PM
SD Overland
SD Overland's Avatar
x2 for above the license plate, although I mounted mine directly in the center. I have an excellent view backing up and can get ultra close to cars behind me for parallel parking like a boss.
I also used a Natika:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
wjkeith likes this.
* 2004 Overland 4.7 HO, IRO 3'', Billstein 4600's, BFG AT K02 245 70R17 *
SD Overland is offline
post #4 of 13 Old 01-17-2020, 01:27 PM Thread Starter
wjkeith
wjkeith's Avatar
You say you didnít have to run wires from the back to the head unit. What about your video feed?
The license plate lamp housing is my first choice. The inside was a second choice after looking for mounting points. Inside appeals to me as itís out of the elements but Iím not too sure what the effect of window tint ( factory) will have on image quality.
wjkeith is offline
post #5 of 13 Old 01-17-2020, 10:53 PM
sparky636
Crawler in Training
sparky636's Avatar
I did above the license plate, as well.
2001, 4.7.
*HK Hidden Winch Mount & Kratos * Dana 30 ARB * JCR Sliders * Trail Forged Fron LAs * RC Long Arm Rear w/ XERO Fab 4 link conversion * 6.5" IRO Springs * Bilstein 5125 * JK Takeoffs * LUX LED & KC HiLite Rock Lights
Instagram: @dolmstead428 @trailmigos
sparky636 is offline
post #6 of 13 Old 01-18-2020, 11:50 PM
68Charger
I am currently working on this very thing right now - does anyone know which wire for the tail-light harness will allow me to splice into the backup lights for the camera?
I heard it was the purple one?
Thanks!
68Charger is offline
post #7 of 13 Old 01-19-2020, 03:36 PM Thread Starter
wjkeith
wjkeith's Avatar
I would like to know if the reverse lights wire is in the passenger side kick panel. If so, what color is it. I know what color it isnít. White/tan, thatís the brake light wire Keith, you idiot! Wiring my camera up today and I got at tad crossed up. Camera works fine. When I apply the brakes! I love getting old.
wjkeith is offline
post #8 of 13 Old 01-19-2020, 03:51 PM Thread Starter
wjkeith
wjkeith's Avatar
Thanks!
Hereís a schematic:
wjkeith is offline
post #9 of 13 Old 01-20-2020, 01:58 PM Thread Starter
wjkeith
wjkeith's Avatar
Thanks!
I corrected my mistake from yesterday. The violet/black wire is accessible in the passenger kick panel wiring harness. All good now. There are two violet wires in there the one you want has a black tracer.
Followed this video for the wiring connections. Works fine.
wjkeith is offline
post #10 of 13 Old 01-20-2020, 02:29 PM
68Charger
This is awesome! Thank you SO much Keith!
Will dig into the wiring sometime afterwork this week.
wjkeith likes this.
post #11 of 13 Old 01-21-2020, 01:44 PM Thread Starter
wjkeith
wjkeith's Avatar
All finished. Pulling the wire harness through the hatch boot was a bit nerve wracking. All in all a project worth pursuing if your head unit supports a camera.
GmanWJ likes this.
wjkeith is offline
post #12 of 13 Old 01-21-2020, 05:41 PM
GmanWJ
GmanWJ's Avatar
Awesome. I very much want to do this, it's always been a pain to see out the rear especially at night. And it would make hooking up the trailer so much easier!
ok mostly just repairs, but we are closing in on a lift
GmanWJ is offline
post #13 of 13 Old 01-21-2020, 06:09 PM
LJ_Comm
I installed mine with a switch on the dash. When I need it I turn it on. It's also used with a video recorder so if anyone is screwing around I have evidence.
LJ_Comm is offline
