Rear sway bar clamp bolt - JeepForum.com
 5Likes
post #1 of 62 Old 05-02-2020, 05:30 PM Thread Starter
Maaadman3
Sooo I broke both bolts trying to remove the clamps, bottom ones easy enough, couldn't drill through it so took a hammer and punch and broke the welds, easy peasy. Upper one.. same thing.. but now I can't get the damn nut out from under the spring perch.. any suggestions? Plenty of threads saying to do the same thing, without a solution to getting the nut out after.
EDIT: Victory has been achieved, a note to anyone just finding this thread and thinking about doing the bushings, use a punch on the bottom bolts if you wish and replace with new bolts. DO NOT DO THE SAME TO THE TOP UNTIL YOU EITHER: A. Drill out the remaining half of the bolt COMPLETELY, or B. Drill and tap the original nut for a new bolt.
Unless of course you want to cut and reweld the bracket and have the equipment to do so then have at er'.
Hopefully this thread will be helpful to anyone in the same situation as me.
Maaadman3 is offline
post #2 of 62 Old 05-03-2020, 03:38 PM
jtpeters
Post a picture.
2004 Jeep Overland WJ 4.7 H.O. (Bought new in Oct 2003)
2014 Jeep Overland WK2 5.7 Hemi (Bought used in 2016 w/7k miles)
1970 Ford Mustang Boss 302 (in Family since 1974)
2013 Ford Mustang Boss 302
2011 BMW 328i
jtpeters is offline
post #3 of 62 Old 05-03-2020, 08:58 PM Thread Starter
Maaadman3
Don't know why it wouldn't let me post these earlier..
Anyway here's the best pictures I could get of the situation
2013 Ford Focus ST (boosted summer fun car)
2000 Jeep Grand Cherokee (old faithful)
post #4 of 62 Old 05-04-2020, 06:18 AM
jtpeters
It's hard to tell, but is that bracket open on the top side?
If so, there's gotta' be a way.
2011 BMW 328i
jtpeters is offline
post #5 of 62 Old 05-04-2020, 07:29 AM
Bigrigr
Bigrigr's Avatar
I agree, maybe a dental pick with a hook on the end?( Mechanic's version)
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #6 of 62 Old 05-04-2020, 08:21 AM Thread Starter
Maaadman3
Yea I tried that.. the problem is the remaining half of the bolt still sticking out of the nut. If it wasn't for that the nut would slide out no issue. I might have to fandangle the nut to shove the bolt half through the hole and take a die grinder to it.. Luckily I have about 4 months to figure it out
post #7 of 62 Old 05-04-2020, 12:37 PM
Double E
Double E's Avatar
Die grinder with the remainder of the bolt sticking through the hole would do the work fast.
Just jam a screwdriver behind it to hold it.
Alternatively, can a Dremel with a tungsten bit get in there and reduce the size enough to get it out?
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #8 of 62 Old 05-04-2020, 03:22 PM Thread Starter
Maaadman3
it MIGHT, but it would probably take a hell of a lot longer. I'll give the die grinder a go first.
Now being that it's this damn difficult to get this out.. How difficult is it going to be to get a new nut in there and hold it with a wrench when I go to reinstall?...
post #9 of 62 Old 05-04-2020, 08:09 PM
Bigrigr
Bigrigr's Avatar
I would think you have enough room for a wrench down from the top? Might have to cut a wrench in half....
Bigrigr is offline
post #10 of 62 Old 05-05-2020, 08:45 AM
CarlJH
2003 WJ
When I replaced all the bushings at the back, I took one look at those bolts and thought NO! leave well alone till you have to really have to change them.
CarlJH is offline
post #11 of 62 Old 05-05-2020, 09:04 AM
xcaliber81
xcaliber81's Avatar
If it was anything like putting a wrench on the passenger side track bar bolt while trying to thread a bolt through it while its flopping around and your half sideways under your jeep should be a nightmare
xcaliber81 is offline
post #12 of 62 Old 05-05-2020, 09:14 AM Thread Starter
Maaadman3
I might see if one of the mechanics at work can lend me one of theirs or something, don't really want to be cutting up my fairly new wrenches...
post #13 of 62 Old 05-05-2020, 10:12 AM
jtpeters
@Maaadman3
Good luck and please keep us informed of your progress and/or final solution.
2011 BMW 328i
jtpeters is offline
post #14 of 62 Old 05-05-2020, 01:04 PM
coldspit47
I went through this on one bolt topside. I tried a coat hanger bent as a hook, I tried pliers, I tried string, I tried a nail set, everything I could think of. After fighting with it for who knows how long I finally said "eff it" since I'm doing an axle swap and took a pair of bolt cutters to the doggone thing and made a small relief cut. now there's a gap in the metal, but a new perch can be welded on OR can put a steel washer/spacer on both sides of the mount. I don't necessarily recommend it, but that's what I did. I haven't run a rear sway in years but will when I swap axles this summer.
04 WJ NV242, IRO 3in, bilsteins, IRO adj UCAs/LCAs/A arm, 265/75/16 Laufenn Xfit, 4.56 gears
coldspit47 is offline
post #15 of 62 Old 05-05-2020, 01:47 PM
Double E
Double E's Avatar
I went through putting a nut in the back as well. I cut some small, fine relief lines on one side of the nut to give it some bite, then found a wedge I could use to hold it in place once it grabbed threads. It tightened down fine.
Put a bit of spray paint on everything once done to keep rust away for awhile.
Double E is offline
