Rear clunking noise - JeepForum.com
 1Likes
post #1 of 24 Old 03-18-2019, 04:22 PM Thread Starter
alferro
Rear clunking noise
I know that a lot has been said about this topic but I can not find the final solution to the problem.
My Jeep is lifted 2 "with OME springs and Rough Country N2.0 shock absorbers, the rear sway bar is eliminated.
This is what i have done for now:
RUCA ball joint replaced.
Stock shock sleeves mounted on RC bushings with M12 screws.
Washers welded on shock mounts.
I have put washers to hold shock bushings.
Spring isolators replaced.
Added a RUCA spacer.
I have tried to drive without shocks and the noise disappears but I don't know if it is caused by the shocks or by some slack in the control arm bushings or for some other reason. The noise only occurs in some rapid rebounds and as the suspension works differently with and without shocks maybe the noise does not come from the shocks themselves.
This clunking noise doesn't look metallic from the inside and i can't hear it from the outside.
Before changing more parts I woul like to know if someone has found finally the origin of this noise and its solution.
1999 WJ 4.7 Limited Quadra Drive
alferro is offline
post #2 of 24 Old 03-18-2019, 06:23 PM
Mattyjm
Mattyjm's Avatar
You have to torque those shocks to spec or beyond, or they'll clunk. I also had RC N2.0s on my 2000 WJ. They clunked until I retorqued them to spec. I also had no added washers or hardware, just the sleeves that came with them.
2004 Special Edition WJ. LOADED!
2004 Rocky Mountain Edition. Froggy Bandit. Wife's Daily Driver. PRISTINE! Stock height and may stay that way.....
Mattyjm is offline
post #3 of 24 Old 03-18-2019, 06:48 PM Thread Starter
alferro
The screws are tightened to 80/85 Ft/Lbs.
alferro is offline
post #4 of 24 Old 03-19-2019, 10:23 AM
Jeeples
Harsh, but fair
Jeeples's Avatar
Rear upper control arm bushings will cause a clunk. They can be replaced vs. buying an entire new arm.
The other, less common, area to look for clunks is the tailpipe mount. If the rubber isolator is worn/stretched you can get an occasional clunk as the bend in the tailpipe contacts the heatshield and/or skidplate for the fuel tank.
SoCal2004wj likes this.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by Jeeples
This is easily the worst post, and thread, I have ever seen in 7 years of being on JF.
Jeeples is offline
post #5 of 24 Old 03-19-2019, 04:18 PM Thread Starter
alferro
A arm bushings were replaced 8,000 miles ago but maybe that's it
alferro is offline
post #6 of 24 Old 03-24-2019, 09:28 AM
MuddyWJ
Did you use mopar bushings? Aftermarket bushings are not know to last on the upper a-arm.
MuddyWJ is offline
post #7 of 24 Old 03-24-2019, 10:33 AM
Mavalon
Have the sway bar links been looked at?
Mavalon is offline
post #8 of 24 Old 03-24-2019, 02:14 PM
Sprung99GC
Sprung99GC's Avatar
I used the KOR bolts and sleeves. Running the same shocks. Torqued them down good and tight. Clunking is gone.
Sprung99GC is offline
post #9 of 24 Old 03-25-2019, 04:27 AM
leadsled jeep
leadsled jeep's Avatar
Ditto. With a lift the stress on these goes up. I replace mine about every 15k with a lifetime warrantee at my parts supplier. Mine started clunking again this week.
'02 4.7HO ~222k ml. 2.5" BDS Springs, All new control arms and Addco Sways. 245-70-17.
leadsled jeep is offline
post #10 of 24 Old 03-26-2019, 08:34 AM
MuddyWJ
Why not just delete the rear sway bar? Personally I see minimal difference with it attached assuming you have the stock pencil thin one.
MuddyWJ is offline
post #11 of 24 Old 03-26-2019, 08:43 AM
LuthWJ77
LuthWJ77's Avatar
Muddy, you ever disconnect front also? I like the idea of this on the trail but wonder if it would feel like it was going to roll over on every turn once I disconnected the front also? Of course low speed stuff nothing on road.
LuthWJ77 is offline
post #12 of 24 Old 03-26-2019, 09:30 AM
Jeeples
Harsh, but fair
Jeeples's Avatar
I can't speak for Muddy, but having driven my WJ around fully disconnected around town in Moab, I'll pass.
Currently I have just the front connected but that's because I need to fab up a pair of spacers for the rear to clear my D44A skid. With the stiff spring rate of my Zone springs I don't really notice much of a difference without the rear, however quicker lane changes (such as swerving to avoid road debris or someone who cuts you off) are a bit unnerving, particularly at freeway speeds.
After an incident on the drive in to work recently I'm more inclined to have the rear sway bar hooked up now too.
Jeeples is offline
post #13 of 24 Old 03-26-2019, 09:36 AM
LuthWJ77
LuthWJ77's Avatar
Yeah kind of what I was thinking. Fully connected with 4" lift w/32" on stock wheels feels like I could roll it over without too much effort. I just rebuilt all the bushings on the rear one might as well leave the flimsy sucker on there then.
LuthWJ77 is offline
post #14 of 24 Old 03-27-2019, 10:08 AM
MuddyWJ
I have 6.5 " on 33s and don't feel unsafe at all without a rear swaybar. I know what my rig is capable of though so I know her limitations.
MuddyWJ is offline
post #15 of 24 Old 03-27-2019, 06:49 PM Thread Starter
alferro
Crown bushings.
alferro is offline
Rear diff noise igorhandsome ZJ Grand Cherokee Forum 13 04-06-2019 11:56 AM
2008 RWD Jeep Liberty Auto - Rear End Noise rm7745 KK Liberty Forum 3 01-14-2019 04:11 PM
Wah Wah noise from right rear fonebone77 ZJ Grand Cherokee Forum 10 01-11-2019 06:23 AM
Why might my ride be so stiff? xUmbra XJ Cherokee Technical Forum 33 12-12-2018 07:40 AM
Need Sherlock Homes for this one....suspension noise on WK MacJeepWk WK Grand Cherokee & XK Commander Forum 9 05-26-2018 07:11 PM
