Rear brake headache - JeepForum.com
 4Likes
  • 1 Post By CarlJH
  • 1 Post By Jonee
  • 2 Post By blueseasons
post #1 of 6 Old 09-10-2019, 10:36 PM Thread Starter
cmwinchester
Rear brake headache
So my rear brakes on the driver side sound like they rub once per revolution until I hit higher speeds (or maybe I cannot hear it anymore). Then when I stop I hear a clicking catching clanking noise from the same location. I did my googling and found out about he caliper bracket and how it tends to wear, so I bought a new bracket and caliper only to have the same noises show back up after 100 miles or so. Any thoughts would be greatly appreciated.
cmwinchester is offline
post #2 of 6 Old 09-11-2019, 05:57 AM
CarlJH
2003 WJ
Parking brake shoes maybe? the pins holding the shoes to the back plate rust and snap, warped rotor, bent axle shaft.
cmwinchester likes this.
CarlJH is offline
post #3 of 6 Old 09-11-2019, 07:46 AM Thread Starter
cmwinchester
I'm leaning toward bent axle shaft. I replaced on both sides the rotors and pads when I wasted money on a new caliper. This WJ only has 57K on it and no accidents. What's the best way to check for a bent axle shaft by ones self?
post #4 of 6 Old 09-11-2019, 11:37 AM
Jonee
2003 WJ
I had a very similar problem as you with my nearside rear and it turned out to be the wheel bearing that was causing the noise.
Jonee is offline
post #5 of 6 Old 09-11-2019, 08:48 PM
blueseasons
Where the heck are people getting these low mileage WJs?
cmwinchester and 2oldjeeps like this.
blueseasons is offline
post #6 of 6 Old 09-12-2019, 06:19 PM Thread Starter
cmwinchester
Bought it from my grand parents after they stopped driving. Truly a car that a little old lady drove to church and to the grocery. Its two wheel drive for now, but hat will soon change. I have already acquired most of what i need for the conversion- 4wd O/D tailhousing, np242, 44a rear w/ variloc, 30 front (both 3.73), 2.5 inch lift, shift selector, front and rear dive shafts. You may wonder why I'm askig about my rear axle when I have these parts already..Well, its hot and humid here in TN. This is a fall project for me, but I'd like to drive the jeep until I do the swap. We'll see how it all goes!
