Rear Axles - JeepForum.com
 1Likes
post #1 of 48 Old 02-09-2020, 08:38 PM Thread Starter
DavesJeep101
Rear Axles
Can someone clarify what rear axles were used in what years/4x4 systems on the WJ's, 44 vs 44a.
DavesJeep101 is offline
post #2 of 48 Old 02-09-2020, 09:04 PM
smokeyyank
None had a 44, only turdy5 or 44a.
http://www.wjjeeps.com/tcases.htm
04 WJ, 4.7HO
3" IRO lift, fastman TB, 32s, lunchbox rear 242HD, 3" exhaust
smokeyyank is offline
post #3 of 48 Old 02-09-2020, 09:38 PM Thread Starter
DavesJeep101
What I was trying to find out is what diff, or both are used in the Quadradrive vs Selectrac. And does the Vari-lok only come in the 44a?
post #4 of 48 Old 02-10-2020, 07:59 AM
GmanWJ
GmanWJ's Avatar
As I understand it, all 4.7L motors had a D44a behind them. All Quadradrive had varilok front and rear. Some Selectrac had varilok rear, it was an option (I have one).
I don't know if all 4.0L had D35 behind them but I think most did, unless they had a factory tow package. I think the D35 did not have a varilok option.
ok mostly just repairs, but we are closing in on a lift
GmanWJ is offline
post #5 of 48 Old 02-10-2020, 08:29 AM Thread Starter
DavesJeep101
More confusing. The chart here http://www.wjjeeps.com/tcases.htm Shows models with only rear LS, Trac Lok 99-01, and Vari Lok 02-04 in 2wd. Quadradrive has front and rear Vari Lok. I'm looking at used trucks right now and several have a 4.0l and Quadradrive. And that's my question, does the 4.0l quadradrive have the 35 or 44a.
post #6 of 48 Old 02-10-2020, 08:32 AM Thread Starter
DavesJeep101
I guess from what I've read you could special order that. What year is your WJ?
post #7 of 48 Old 02-10-2020, 08:46 AM
Bigrigr
Bigrigr's Avatar
I do not know exactly, but i believe that the Quadradrive system WAS available behind the 4.0L, but it appears to be very rare here where I'm at. I have seen one jeep setup this way in the wrecking yard. I did not investigate super close, but it appeared to have the 44A rear diff. I believe that the only thing you got with the quadradrive system was the dana 30 front, and the dana 44a rear. I have never heard of, nor seen a dana 35 rear with vari-lok. And quadradrive always has vari-lok axles.....
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #8 of 48 Old 02-10-2020, 09:33 AM
GmanWJ
GmanWJ's Avatar
I have a 2002 Laredo 4.7L SelecTrac Class IV tow package Up Country with varilok rear diff, Patriot blue no sunroof. Told the dealer that is what I wanted back in 02 and he found one for me.
GmanWJ is offline
post #9 of 48 Old 02-10-2020, 09:37 AM
GmanWJ
GmanWJ's Avatar
Easiest way to identify D35 vs D44a is look at the shape of the diff cover. Not too hard to get a visual on it if you are on site with the rig.
Waterluvr likes this.
GmanWJ is offline
post #10 of 48 Old 02-10-2020, 02:33 PM Thread Starter
DavesJeep101
I'm in CA and there are a few popping up with the Quadradrive that are 4.0L.
post #11 of 48 Old 02-10-2020, 09:26 PM
Bigrigr
Bigrigr's Avatar
They SHOULD be dana 30/dana 44A then...like i said, ive never heard or seen a quadradrive without the 44A
Bigrigr is offline
post #12 of 48 Old 02-10-2020, 09:38 PM
GmanWJ
GmanWJ's Avatar
I just realized that in the pic I posted, the D44 is the standard model and not the D44a. They are similar though. The D35 cover is accurate.
GmanWJ is offline
post #13 of 48 Old 02-12-2020, 03:04 PM Thread Starter
DavesJeep101
More Axle Talk
So this thread was to try narrow down what WJ to buy. Lot's of talk about Quadratrac having the Vari-Lok diffs and how that is a good option to put a 242 TC in. But they are not serviceable, so how durable are they? Replacement carrier availability down the road? Also reading about Trac-Loc not really being any good. What options are available for other LS carriers in the 44a vs the 35 axle.
Not really interested in a lunchbox type locker but would consider a selectable for the rear at some point if I end up with open diffs. Like I said before, no serious wheeling but I will be in somewhat remote places and alone at times. Also likely won't go bigger than 33's.
post #14 of 48 Old 02-12-2020, 03:42 PM
smokeyyank
ARB or lunchbox are the only options. Why are you opposed to a lunchbox style out of curiosity?
04 WJ, 4.7HO
post #15 of 48 Old 02-12-2020, 06:16 PM Thread Starter
DavesJeep101
Seems opinions on them are 50/50 and I'm somewhat turned off by some of the sounds that come out of them. Tell me something good about your experience with them, maybe something to consider with more info. Definitely an easier, lower cost option. I'm limited on funds but I understand buy once, cry once.
