Random white plug in center console - JeepForum.com
 1Likes
  • 1 Post By WJ60
post #1 of 7 Old 10-13-2021, 09:35 AM Thread Starter
metal4fun
I removed my center console and noticed a white plug on the driver's side near the transmission tunnel. It was wrapped in plastic like it was never used from the factory and was curious of what accessory it might go to? Depending on what it is meant for, could I possibly use the circuit for another mod? The cables are solid purple and black
metal4fun is offline
post #2 of 7 Old 10-13-2021, 11:04 AM
Mr. Bitey
Mr. Bitey's Avatar
The BLK is ground. There is a solid PRP for the FR+ speaker, but not sure why it would be in a connector in the console. It must have a different designation in that circuit. Interesting - following!
2004 WJ, 4.7 N, daily driver.
1967 Jeep J100 panel truck (a-rusted development)
1970 'Cuda, 340 4bbl (10.952et @ 123mph)
1972 Dart Swinger, Gen III 6.4l Hemi (in progress)
1974 AMC Gremlin X, 440 6bbl (trailer queen, 9.466et @ 144mph)
1975 Jeep Cherokee Sport 2-door (in progress)
Mr. Bitey is online now
post #3 of 7 Old 10-13-2021, 07:19 PM
Brallen86
Brallen86's Avatar
2003 WJ
The FSM designates purple as violet or "VT" but I just finished combing through the FSM looking for this combo of a "VT/BK" of a "White 2 Way" connector and came up with NADDA!
Out of curiosity I'll have to take a gander on mine and see if it's there and what it may be hooked up to when I get back on the interior.
My guess is either power port or heated seats, heated seats probably not though since it's only a 2 wire connector. A DMM on it while the vehicle is on should give some more info though.
-03 WJ Limited; Check out my
Brallen86 is offline
post #4 of 7 Old 10-13-2021, 07:28 PM
xcaliber81
xcaliber81's Avatar
Its routed in the wrong place for seat heat or power they both are right behind the ash tray.
xcaliber81 is offline
post #5 of 7 Old 10-13-2021, 11:35 PM
WJ60
WJ60's Avatar
I believe it's a power connector (think spare for powering an add on). Use a voltmeter and see if it shows 12vdc. I'm including snips from a service manual. Page 8W-91-9 lists it as a white connector.
Mr. Bitey likes this.
'77 Chevy C10 pickup
'01 WJ 60th Anniversary Edition
'13 Dodge Dart Rallye
WJ60 is offline
post #6 of 7 Old 10-14-2021, 12:39 PM
#1EasyXjer
#1EasyXjer's Avatar
Do you have 2 power plugs in lower area in front of shifter? If not mine does. Could be aux power port.
#1EasyXjer is offline
post #7 of 7 Old 10-15-2021, 06:17 AM Thread Starter
metal4fun
metal4fun
I do have both power plugs in front of the shifter and both are connected.
