Radio: I am already frustrated - JeepForum.com
post #1 of 16 Old 03-11-2019, 04:28 PM Thread Starter
CBrendemuehl
I have this nice Pioneer AVH491 that I was planning on installing.
But when I take out the old radio ... no luck. It's a bit too tall to fit.
What's the solution?
CBrendemuehl is offline
post #2 of 16 Old 03-11-2019, 06:18 PM
frankjc
Installation kit?
frankjc is offline
post #3 of 16 Old 03-11-2019, 06:44 PM
SD Overland
SD Overland is offline
post #4 of 16 Old 03-11-2019, 07:11 PM Thread Starter
CBrendemuehl
Oh I have the installation kit. It appears that I will have to remove metal. Didn't see anything like that in the videos on YouTube.
post #5 of 16 Old 03-11-2019, 09:45 PM
xcaliber81
You probably have a double din head unit.
xcaliber81 is offline
post #6 of 16 Old 03-11-2019, 10:21 PM
ddawg16
ddawg16's Avatar
Radio? People still put radios in jeeps?
I haven't had a radio in my CJ for over 20 years.
Even if I did, I wouldn't be able to hear it
ddawg16 is offline
post #7 of 16 Old 03-11-2019, 10:48 PM
speedymopars
Wj'are 1.5 DIN, pioneer is the std double din. You need to cut to get things to fit.
86 CJ7 spooled 5.38's armored and caged
01 WJ LTD UC+BB 4.7, 33's
15 WK2 OVLD Diesel, Green Eng
speedymopars is offline
post #8 of 16 Old 03-12-2019, 05:49 AM
FanTech
Yep.. either return and get a single DIN size unit, or you can buy a double DIN adapter face plate. Some people trim them, but they usually look pretty hacked up...
"SD Overland" posted the most commonly available adapter.
FanTech is offline
post #9 of 16 Old 03-12-2019, 07:34 AM Thread Starter
CBrendemuehl
Yes, it is a double-din.
(In the real world we might say 2U. But nobody understands that. *sigh*)
Did find a video that showed everything being cut up. Not really the direction I want to go.
I'm looking for a nice 1.5 high unit now.
Do want hands-free. Many states I drive through now require it. (IL & NY) And it is generally safer.
post #10 of 16 Old 03-12-2019, 07:39 AM Thread Starter
CBrendemuehl
post #11 of 16 Old 03-12-2019, 06:28 PM
xcaliber81
I like my single din alpine. I dont want to butcher my wj either.
post #12 of 16 Old 03-13-2019, 12:03 AM
Jay311md
Pretty easy to install, only took a day. Some modification is needed to the dash, but nothing too bad. If you have the infinity gold system, you can keep the amp and speakers and just replace the head unit. I added satellite, hands free, android auto/apple carplay, and it's a touch screen. Technology of the new jeeps in an old body. Love it.
Jay311md is offline
post #13 of 16 Old 03-13-2019, 08:07 AM Thread Starter
CBrendemuehl
Well-done.
Looks like I have to buy my first angle grinder to get the metal out. Correct?
Also, I like your burl. Have to find some of that for mine.
post #14 of 16 Old 03-13-2019, 02:21 PM
willis36
willis36's Avatar
Well-done.
Your going to want a dremel tool with a cut off wheel in that tight space. Prepare for lots of cutting, not much room in there.
willis36 is offline
post #15 of 16 Old 03-13-2019, 05:09 PM
Jay311md
It really isn't that bad. I used a Dremel and an air saw on my compressor. There's not metal back there to cut. It's all plastic. You'll but out the plastic bracket behind the bezel, but not the edges. And then trim the top to fit. It is pretty tight, but I shoved all the excess cables and boxes to the both sides. I got the axxess box to keep the steering wheel controls as well.
The hardest part was modifying the new double din bezel. You have to remove the vents from the old bezel to put on the new ones. Once you get the old bezels off and trimmed to fit the new bezel, I just used a flathead screwdriver and a torch to plastic weld the vents in place.
Hope some of that helps. Let me know if you need anything. It is well worth it.
Jay311md is offline
The Johnny 5 Build -Syntax- Jeep Builds 51 03-08-2019 10:25 AM
Infinity Sound System 95 ZJ with Kenwood radio. muddflow ZJ Grand Cherokee Forum 39 10-25-2018 09:54 AM
replacement radio 430 rbz britord WK2 Grand Cherokee Forum 6 10-02-2018 04:21 AM
replacement radio 430 rbz britord WK Grand Cherokee & XK Commander Forum 2 10-01-2018 06:19 PM
Radio has constant power ClayPannell Audio, CB & Ham Radios, GPS, & Electrical 0 09-16-2018 09:03 PM
