Quadradrive Vari-Lok Mod Thread - JeepForum.com
post #1 of 26 Old 12-09-2017, 07:42 PM Thread Starter
Monzsta
Ok guys. Last weekend came and went, and I got nothing done due to being socked with the flu or some ungodly other virus. Wasted not only the weekend but two work days with fever and sick in bed. Not to mention the threat of snow which meant the Jeep needed to be in ready order.
Now that is getting out of me I have some work to do. I'll update this thread heavily tomorrow with pics and a good write up.
Monzsta is offline
post #2 of 26 Old 12-09-2017, 08:15 PM
03CUSEWJ
2003 WJ
Been lurking around this site waiting for this. Feel better, man!
03CUSEWJ is offline
post #3 of 26 Old 12-09-2017, 08:32 PM
IOwnCalculus
Following this as well.
IOwnCalculus is offline
post #4 of 26 Old 12-10-2017, 12:51 PM
bugaboots
Be interested in seeing this.
2002 Grand Cherokee Sport, IRO 3" Rock-Link, Bilstien 5100's, IRO 2.5 exaust, 4.7L long rod stroker
bugaboots is offline
post #5 of 26 Old 12-10-2017, 08:07 PM
coopdc78
2005 WK
We got some here! Where ya from? Watching thread as well
2004 overland 4"long arm lift
2005 wk stock
2000 camaro ss/slp w/10,000 miles
coopdc78 is offline
post #6 of 26 Old 12-13-2017, 07:57 AM
bamarider1
Looking forward to your write up.
bamarider1 is offline
post #7 of 26 Old 12-20-2017, 08:24 PM
JMZ101586
So....
Stable:
04 WJ Special Edition 4.7
98 Camaro SLP SS with LS2 swap
05 STS4 4.6 Northstar AWD
JMZ101586 is offline
post #8 of 26 Old 01-06-2018, 12:13 PM
Redjeepwj
Cool Vari loc
Did I miss this write up?
Redjeepwj is offline
post #9 of 26 Old 01-06-2018, 02:44 PM
JMZ101586
Can't miss what doesn't exist.
Stable:
post #10 of 26 Old 02-04-2018, 07:11 AM
JeepN95YJ
I know life gets busy. Hope you can drop in and give us an update.
JeepN95YJ is offline
post #11 of 26 Old 10-23-2018, 08:54 PM Thread Starter
Monzsta
Back from the dead.
So where am I? Oh yeah. VariloK Mod. For those that are just seeing this thread, here's a brief synopsis.
The stock VariloK is a good unit. However it isn't a locker, it's an on demand limited slip. When one wheel spins... well you guys know the rest. What is little known however is that this unit has a pressure relief valve in the hydraulic circuit, limiting the absolute apply the pump can direct to the clutch pack.
This mod eliminates that relief valve, giving the VariloK the capability of 100% lock. Bear in mind this isn't a locker, even after the mod. It's still transparent in normal driving. It will still bleed down after lock up, This mod just allows it to lock harder.
To get to the pressure relief valve you have to remove your carrier. Then you have to remove the bearing on the ring gear side. This is a great time to regear or freshen up the bearings.
using a puller, torch, cut off wheel, your teeth, what have you, remove the bearing. If you go by the dealer they have the special tools to remove the bearing and most times it stays intact, but don't count on it. Pictured is the special tools.
Next you pull off the fluid pickup plate.
Underneath that you'll see a little metal reed held down with two tiny Allen screws. This is the pressure relief valve.
Once you remove this spring you'll see a little steel ball in a pocket.
You can either remove the ball, tap and plug the hole, weld it shut, or as I did, use a prick punch to close the metal around the ball locking it in place.
Then reinstall the pickup plate and bearing, and pop it back in the housing. Easy peasy!
20180917_072251.jpg   20180917_072641.jpg   20180917_155032.jpg   20180917_154810.jpg   20180917_072634.jpg
Monzsta is offline
post #12 of 26 Old 10-23-2018, 08:59 PM Thread Starter
Monzsta
After I got it back together I could tell an immediate difference beating around my property. My worn out cv axles were clicking much harder during turns and lodging the jeep in an off camber uphill climb resulted in heavy wheel spin from both tires where I could usually just get one to spin.
Monzsta is offline
post #13 of 26 Old 10-24-2018, 07:27 AM
jserna
1987 YJ Wrangler
Haha!! Wow that is it, Crazy! Does it look like that ball valve could come out?
jserna is offline
post #14 of 26 Old 10-24-2018, 01:45 PM Thread Starter
Monzsta
Well, yeah, with the flat spring off it'll fall right out. There's a seat under there that the ball seals against. By peening it I'm preventing it from moving off the seat.
I did reinstall the spring plate over it.
Monzsta is offline
post #15 of 26 Old 10-26-2018, 02:40 PM
speedymopars
This is awesome, thanks. What would be great is to slow down the bleed off, so once there is slip, it would lock for a minute or two. This would be great on the rocks and soft stuff so you wouldn't need a ton of wheel spin every 10 feet to keep going.
Do you think there is a way to control bleed off time? Do that with the pressure mod, you may have the closest thing to a locker you can get with this.
86 CJ7 spooled 5.38's armored and caged
01 WJ LTD UC+BB 4.7, 33's
15 WK2 OVLD Diesel, Green Eng
speedymopars is offline
