Quadra-Trac II - JeepForum.com
 12Likes
post #1 of 23 Old 02-13-2020, 01:26 AM Thread Starter
the cueball
the cueball's Avatar
1936 CJ2A
Quadra-Trac II
Morning all....
Am I correct in thinking that my WJ with the above system is rear wheel drive most of the time, then it uses hydraulic pressure to ‘switch’ it to all wheel drive?
We’ve just started to get snow here and this morning my Jeep was there just spinning it’s rear wheels not going anywhere...
I’m guessing the ‘switch’ should happen quickly and not take 5 minutes or something daft??
It was in Drive and 4WD high (most forward selection) and I have decent Yoko Geolander tyres all round.
Had to give up and drive by the stranded Jeep in my Audi... the shame! Lol
Sent from my iPhone using Tapatalk
the cueball is offline
post #2 of 23 Old 02-13-2020, 05:17 AM
CarlJH
2003 WJ
yes thats basically whats ment to happen, in normal use the front and rear propshafts turn at the same speed, when one starts going faster it pressurizes the vari-loc in the TC and locks, it should only take no more than 1-2 wheel revolutions for it to kick in, once both ends are turning spinning at the same speed the vari-loc will release.
in 4low its physically locked.
the cueball likes this.
CarlJH is offline
post #3 of 23 Old 02-13-2020, 07:22 AM
HampshireWJ
HampshireWJ's Avatar
2003 WJ
Sound like something ain't right there - have a read of the The Four Wheel Drive section of this - https://www.jeepforum.com/forum/f310.../#post12259930 - it should explain things. Carl is right though. Have a go in 4 low and see what happens.
HampshireWJ is online now
post #4 of 23 Old 02-13-2020, 08:00 AM
Bigrigr
Bigrigr's Avatar
Sounds like the Progressive coupler in the TC is either shot, or the fluid is extremely low, or in need of a change. My 247 TC was way low on fluid when i brought it home, and it acted like this.
I also have the Quadra Trac II system....or used to...
More than likely you also have open diffs front and rear, it's possible you were siting there only spinning one tire!!! That is shamefull!
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #5 of 23 Old 02-13-2020, 08:14 AM Thread Starter
the cueball
1936 CJ2A
I’ll try the 4low and see how I get on.
Thanks for the link, I’ll have a read of that too.
I’m about to carry out a diff/transfer oil change, so I may get lucky and that will solve the issue.
One wheel eh... not sure I can handle that level of shame
post #6 of 23 Old 02-13-2020, 08:16 AM Thread Starter
the cueball
1936 CJ2A
Quadra-Trac II
Last edited by the cueball; 02-13-2020 at 08:16 AM. Reason: Getting sick of Tapatalk
post #7 of 23 Old 02-13-2020, 08:19 AM
CarlJH
2003 WJ
you could try a bit of left foot braking to fool it into thinking its got more grip and limit the wheel spin, a bit like how modern traction control works.
Ttim and the cueball like this.
CarlJH is offline
post #8 of 23 Old 02-13-2020, 08:28 AM
HarryH3
Yes, it should be nearly instant. While mine has QuadraDrive (with the VariLoc diffs front and rear), it uses the same 247 transfer case as yours. I can barely feel the rear tires slip at all before the front engages.
99SK04GTX and the cueball like this.
HarryH3 is offline
post #9 of 23 Old 02-13-2020, 01:01 PM Thread Starter
the cueball
1936 CJ2A
I tried the 4lo on the way home and I can feel that all 4 wheels have traction.
I’ll be doing the oil change in a couple of weeks, so I guess fingers crossed that’ll fix it!
post #10 of 23 Old 02-13-2020, 01:18 PM
CarlJH
2003 WJ
remember it needs a tractor UTTO oil like mobilefluid 424 or Synergy Harvella UTTO 10W-30, Westway on ebay also have there version too.
CarlJH is offline
post #11 of 23 Old 02-13-2020, 03:20 PM
LuthWJ77
LuthWJ77's Avatar
I thought the 247 needed the special mopar stuff?
https://www.amazon.com/Genuine-Chrys.../dp/B008Y791O2
LuthWJ77 is offline
post #12 of 23 Old 02-13-2020, 04:07 PM
CarlJH
2003 WJ
LuthWJ77 that's what the Mopar stuff is, just with a big blue M label and a bigger price tag!
CarlJH is offline
post #13 of 23 Old 02-13-2020, 04:40 PM
Spyder62
Spyder62's Avatar
With Quadra trac 2 your not gonna get all wheel drive.(4 wheels spinning) Only one wheel on each differential will spin at a time.( Open differentials) it’s possible you have an optional limited slip in the rear. (Both wheels spin in the rear)For the most part 4 wheel drive is actually two wheel drive. Onewheel spins in the front and one wheel spins in the rear.
Spyder62 is offline
post #14 of 23 Old 02-13-2020, 07:52 PM
2oldjeeps
i bought the right juice at a jeep dealer at a good price...
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #15 of 23 Old 02-13-2020, 10:17 PM
HampshireWJ
2003 WJ
Glad it worked in low range. Talk to Greg on the number on this link he'll supply you this https://www.4playjeep.com/product/tr...icant-5-litre/ - which is the fluid I have used and all is good. Greg does talk a bit!
