Quadra Drive binding? - JeepForum.com
 11Likes
post #1 of 19 Old 02-17-2020, 05:17 PM Thread Starter
NWDC
NWDC's Avatar
Hey guys- I'm experiencing a groaning noise coming from the rear end when I turn tightly in either direction. I've read a few posts about binding and also tried to find some videos of other people experiencing this, but I still don't know where it is coming from. Any ideas on what would be causing this?
This guy I bought the vehicle from has a receipt from two months ago of both front an rear differentials getting fluid changed at jiffy lube and they used Penzoil GL5 75W-140, which i've read already has a friction modifier added to it.
NWDC is offline
post #2 of 19 Old 02-17-2020, 06:12 PM
Photoweborama
Photoweborama's Avatar
I get some from a Jeep dealer and put more in. In my experience, it needs a whole bottle in both diffs. No telling how much was in the oil they put in. Basically, if itís binding on sharp turns, you need more..
This is in AWD right? Not in 4 low...
Sent from my iPhone using Tapatalk
NWDC likes this.
Photoweborama is offline
post #3 of 19 Old 02-17-2020, 06:39 PM Thread Starter
NWDC
NWDC's Avatar
Yeah its happening in AWD. I actually pulled the fill plugs on both diffs yesterday to check diff fluid level and it was right where it was supposed to be so maybe I need to just add more friction modifier like you said. The rear diff fill hole is right up next to the gas tank, any suggestion on how to get fluid in there?
NWDC is offline
post #4 of 19 Old 02-17-2020, 07:44 PM
SoCal2004wj
SoCal2004wj's Avatar
Jack it up from the "frame" and it will lower the differential enough to access the fill hole. The other option is to use a hand pump or 60cc syringe.
NWDC likes this.
SoCal2004wj is offline
post #5 of 19 Old 02-17-2020, 10:04 PM
Bigrigr
Bigrigr's Avatar
Did you double check the transfer case?
NWDC likes this.
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #6 of 19 Old 02-18-2020, 08:42 AM
HarryH3
... they used Penzoil GL5 75W-140, which i've read already has a friction modifier added to it.
It does, but not nearly the amount that VariLok diffs like in order to be quiet. The clutches in them are pretty aggressive. The extra friction modifier takes a while to work its way into the clutches, but the noises will fade away within a few days of driving (or you can drive around in figure 8's in a parking lot for 5-10 minutes to speed things along).
Also note that in 20-25K miles the noise will return, to remind you that it's time to change the lube again.
HarryH3 is offline
post #7 of 19 Old 02-18-2020, 09:30 AM
bluepen61
You have to become quite anal when dealing with shops when having your diff's and transfer case oils changed. The oils are expensive. Replace the oils at a competent shop stressing Quadra Drive. Both front and rear diffs are limited slip.
Sent from my Moto Z (2) using Tapatalk
NWDC likes this.
bluepen61
2004 WJ Limited
2015 WK2 Limited
bluepen61 is offline
post #8 of 19 Old 02-18-2020, 09:45 AM Thread Starter
NWDC
NWDC's Avatar
Yeah I actually just changed the rear TC seal yesterday on my NV 247 and filled it with new 247 TC fluid. I didn't add any friction modifier to that though, didn't think it needed it. The binding noise was occurring before and after that TC fluid swap so I assumed that it is something else.
NWDC is offline
post #9 of 19 Old 02-18-2020, 09:47 AM Thread Starter
NWDC
NWDC's Avatar
Good call, I should have thought to raise it up. Will do that next time i'm working on the diffs-
NWDC is offline
post #10 of 19 Old 02-18-2020, 09:49 AM Thread Starter
NWDC
NWDC's Avatar
Thanks for the info, is this the right friction modifier or is there specific types of friction modifier for each differential?
https://www.amazon.com/Genuine-Mopar...SIN=B000TTEX8W
NWDC is offline
post #11 of 19 Old 02-18-2020, 09:52 AM
GmanWJ
GmanWJ's Avatar
x2.
I tried some of the Valvoline 75W-140 "with friction modifier" thinking I wouldn't need the Jeep FM and had the exact same issue. Go to the Jeep dealer, buy a bottle of their FM, and squirt it in there. I use about half a bottle in the rear.
Jiffy Lube is a great place for oil changes if you really just don't care much about your car, because they don't either and it shows.
wildbill23c and NWDC like this.
ok mostly just repairs, but we are closing in on a lift
GmanWJ is offline
post #12 of 19 Old 02-18-2020, 11:31 AM
HarryH3
[URL="https://www.amazon.com/Genuine-Mopar-4318060AC-Limited-Additive/dp/B000TTEX8W/[/URL]
That's the stuff. The manual specs 4 ounces in the rear diff and 2.5 ounces in the front diff (the front diff holds much less lube than the rear). Call your local Jeep dealer before clicking add-to-cart. Sometimes they have decent prices on that stuff.
NWDC likes this.
HarryH3 is offline
post #13 of 19 Old 02-18-2020, 11:38 AM
HarryH3
Just thought of another item that is VERY important to keep a QuadraDrive rig engaging all 4 wheels when needed. You need to always do 5-tire rotations, keeping the spare in the rotation, to keep tire wear even. I rotate mine every 5K miles. You also need to make sure that all of the tires the same size (and preferably even the same brand/model, since not all "marked" sizes are exactly the same). Running with (even slightly) different diameter tires on a VariLok equipped axle can cause the diff to always slightly engage at higher speeds. This causes the clutches to drag and wears them out quickly (they're trying like mad to make the slower tire catch up). The same thing can happen to the progressive coupler inside the t-case if you don't keep the front and rear tire diameters matched. Mine just rolled over to 156K last night and the clutches still engage fast and hard.
Bigrigr and NWDC like this.
HarryH3 is offline
post #14 of 19 Old 02-18-2020, 11:47 AM Thread Starter
NWDC
NWDC's Avatar
For sure, i've actually picked up some other fluid from the dealership and is most definitely cheaper for fluids when factoring in shipping prices. I've found that some of the Mopar replacement parts are overpriced at the dealership but its always worth shopping around for.
NWDC is offline
post #15 of 19 Old 02-18-2020, 11:54 AM Thread Starter
NWDC
NWDC's Avatar
That's a good point. I'm planning to lift and put new tires/wheels on in the next few months so I will likely just wait for that.
I do plan to use the WJ to go up to the mountains out here, in snowy conditions, and i'm wondering if I should chain up all 4 tires in that case if needed? I read in the owners manual to only chain up the rears, but I figured that was considering at stock height, the front tires don't have much clearance from the wheels wells and fenders. Either way, I don't plan to spend a significant amount of time driving with chains but still don't want to mess up the diff clutches-
NWDC is offline
