Pulling to the left under moderate to heaving braking - JeepForum.com
 1Likes
  • 1 Post By HarryH3
post #1 of 9 Old 10-14-2017, 03:23 PM Thread Starter
ScottTee
Wj Pulling to the left under moderate to heaving braking
Before the pulling to the left thing started, I did the following work in this order:
1. Replaced broken right front pads
2. Replaced steering gear box. (new pitman arm. Couldn't get the old one off)
I checked the right caliper to make sure it wasn't stuck after this started happening. Both pistons are moving ok, it seems. I don't think the right caliper pistons are stuck.
Could this be a steering related issue? I did not get an alignment after replacing the gear box.
If not, what else might it be?
Thanks,
Scott
ScottTee is offline
post #2 of 9 Old 10-14-2017, 03:34 PM
jtec
jtec's Avatar
2014 JK Wrangler
How were the front pads 'broken'? worn we understand but broken IDK.
pulling left could be a left calliper issue SO did you you check that side, hopefully you did NOT allow calipers to hang on brake hose or twist hose when reinstalling calipers.
I would take a ride confirm pulling left then open caliper bleeder observe is fluid spurts
out as under pressure.
The pulling was NOT there before gear box replaced?
jtec is offline
post #3 of 9 Old 10-14-2017, 03:55 PM Thread Starter
ScottTee
"Broken" may be over stating it. One pad was cracked and half of it was crumbling apart. The left front pads were Ok - about half life left.
I checked the right caliper pistons - they seem ok. May have to check again....
The pulling was not there before the gear box and pads were replaced. For sure.
ScottTee is offline
post #4 of 9 Old 10-14-2017, 03:58 PM
jtec
jtec's Avatar
2014 JK Wrangler
you did pads on 1 side only?
lets look at the L/S caliper first...
jtec is offline
post #5 of 9 Old 10-14-2017, 04:14 PM
HarryH3
You should replace the pads on BOTH sides. If you mix pads they may have different friction characteristics and cause, wait for it!, pulling to one side.
Also check rotor temps after a short drive. That right caliper may be dragging a bit and getting the pads way too hot. That would explain the crumbled brake pads.
97Mule likes this.
HarryH3 is offline
post #6 of 9 Old 10-14-2017, 06:32 PM Thread Starter
ScottTee
That's probably it - need to do the left pads... Didn't think it would make that big a difference.
Sent from my Nexus 5X using Tapatalk
ScottTee is offline
post #7 of 9 Old 10-16-2017, 03:52 AM
dlundblad
2003 WJ
Pulling left means your right brake is wonky.
Your left brake is working fine.
03 WJ Laredo 4.Sl0w
2" BB-Overland Skids
IPF 868 lights-197K
245/75/16 GY DuraTracs
dlundblad is offline
post #8 of 9 Old 10-24-2017, 07:06 PM
wsar10
2003 WJ
X4 always replace all pads at the same time.
However after owning a WJ for over a decade (and Jeeps in general for even longer) I can tell ya that you have a caliper seizing. They usually start as your describing then stick all the time. Also never let a WJ caliper hang or fall and be caught by the line, they have a check valve in thag line and it will then start to stick. Make sure you get a caliper with a good warranty, because you will need it, they are junk!
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #9 of 9 Old 10-24-2017, 07:20 PM Thread Starter
ScottTee
There was no dragging.
The right brake is fine.
Replaced the left pads and after a couple of days the pulling diminished.
ScottTee is offline
