Power window wiring diagram? - JeepForum.com
post #1 of 16 Old 09-21-2014, 07:19 PM Thread Starter
PatriotBlue02WJ
Anyone have one? Searched and came up with nothing. Driver's side rear went partially down today and never came back up (or finished going down). Its been slow for awhile. I took the door panel off and tried to pin out the connector to see if power was getting to it. I got 12V when the master switch on the driver's door was switched down. But got nothing in any of them while trying to go up (but not sure which wire to test). Trying to locate a wiring diagram to help troubleshoot the issue. Thanks!
PatriotBlue02WJ is offline
post #2 of 16 Old 09-22-2014, 08:57 AM
jserna
1987 YJ Wrangler
Pull the boot in between the door and body. You more then likely have a broken wire in there. I had the same issue last year and pulled the panel only to find the broken wire in the boot.
jserna is offline
post #3 of 16 Old 09-22-2014, 09:47 AM Thread Starter
PatriotBlue02WJ
In the passenger door, or driver door? I had found stuff about this in my search, but would really like to know what wire colors I'm looking for. Guess its time to check out the local parts store for a manual.
post #4 of 16 Old 09-22-2014, 10:11 AM
Darnice
FYI, theses do not "drive" the windows from the drivers switch. The Drivers switch talks to the door modules over the data bus. The drivers panel is the master.
If a Drivers door wire is damaged, it can cause this.
Also, rapidly move the rear window switch at the drivers position. Up/Down/Up/Down, see if the window responds.
Darnice is offline
post #5 of 16 Old 09-22-2014, 05:43 PM Thread Starter
PatriotBlue02WJ
rapidly moved both switches (not at the same time), nothing moved.
post #6 of 16 Old 09-22-2014, 05:45 PM
morson82
What are symptoms of a bad module? Both r/s windows on my 04 won't work. Have power (orange wire) to the module (r/f) but the window will not go down or up. It will however work via the master.
morson82 is offline
post #7 of 16 Old 09-22-2014, 07:09 PM Thread Starter
PatriotBlue02WJ
Weather is horrible out there tonight, no progress to report. If it is the regulator/motor, is there a recommended brand to go with for replacement? When they die, do they not make any noise? I get nothing, no clicking, no grinding.
post #8 of 16 Old 09-24-2014, 10:03 AM Thread Starter
PatriotBlue02WJ
Was able to fix it last night. It was the red and blue wires in the door jam. Pulled the boot back and bingo, blue was disconnected and the red one pulled apart with one tug. Turns out it had been repaired once before. They did a very nice job with it, using the correct heat shrink size (dealer maybe?). My guess is that it was just too much tension and it pulled apart. I put a small jumper in and its back up and running. Thanks for all the help!
post #9 of 16 Old 09-24-2014, 04:40 PM
jserna
1987 YJ Wrangler
Good job!
jserna is offline
post #10 of 16 Old 06-24-2021, 02:02 PM
SteveMann
2003 XJ Cherokee
Old post, solved my problem today
I really appreciate that old posts stay on the forum. The windows on my 2003 Grand only worked when the door was closed. I took the door panels off hoping to see a loose connector. Finding nothing, I replaced the door panel. Now nothing worked. And the window was half down. Now I had to find the problem.
This post pointed me to the wire bundle inside the boot- and I found two broken wires. Repairing them took a few hours, but now everything works as expected.
Now, I have a new problem. How do I replace the boot over the plastic sleeve?
SteveMann is offline
post #11 of 16 Old 06-24-2021, 02:58 PM
blueseasons1
Which door jam? The Drivers door or the door for the window that didnt work?
blueseasons1 is offline
post #12 of 16 Old 06-24-2021, 03:01 PM
blueseasons1
Its a PITA and eventually I gave up. I got it as far as I could then used some electrical tape to hold it there and keep water out.
post #13 of 16 Old 06-24-2021, 03:53 PM
2oldjeeps
2oldjeeps's Avatar
haynes books give me 100% of needed wire info. i buy a new car,buy the haynes on the way home...
windows/locks are 99 % wire trouble.
the computer bus HAS NOTHING TO DO WITH IT...
and, if a motor goes up,OR down, its ok...
99wj, 150,000 miles
00xj ,189,000 miles
10hummer3,76,000 miles
98xj, 133,000 miles
2oldjeeps is offline
post #14 of 16 Old 06-25-2021, 08:50 AM
GmanWJ
GmanWJ's Avatar
Remove the sleeve from the door. Fit the sleeve inside the rim of the boot. Then snap the sleeve/boot back in the door.
2.5" OME HD & Bilsteins
Dual Batteries
Aux Trailer Hookups (4awg charging & backup cam)
GmanWJ is offline
post #15 of 16 Old 06-25-2021, 01:09 PM
SteveMann
2003 XJ Cherokee
How do I remove the sleeve? Do I need to remove the door panel again?
