Power steering hose help on 4.7 WJ - Page 3 - JeepForum.com
 1Likes
post #31 of 44 Old 06-06-2017, 01:02 PM
703JRB
2003 WJ
Anybody have experience of Edelmann stuff? I can get their's next day over here in the UK, but the dealer wants 4 weeks for OEM or 10 - 15 days from US eBay sellers.
Joe
703JRB is offline
post #32 of 44 Old 06-07-2017, 12:40 AM
sdg3205
sdg3205's Avatar
I'm running an Edelman. Is it good? who knows... it's only been a few months but no issues.
sdg3205 is offline
post #33 of 44 Old 06-07-2017, 03:16 PM
blueseasons1
As I said above, I bought a GATES replacement hose. I did have to wrestle with it to get it installed. It looks easier than it is. However. It's not the threads that make the seal. Its the little black "O" ring at the bottom. If you twist or tweak that during the installation, its gonna leak. I buggered up mine with heavy dose of Vaseline to hold it in place during the operation. Mine has been on a couple of months now and its all good.
blueseasons1 is offline
post #34 of 44 Old 06-21-2017, 06:15 AM
703JRB
2003 WJ
So I changed the hose, with a MOPAR version I managed to find in stock in the UK, not bloody cheap!
Anyway apart from the top fitting being an absolute ***** to get in without cross threading it, the bottom fitting is now weeping. The hose I got had this fitting supplied unattached, so I slid that onto the end of the hose, I can't see or think of doing it differently to how I did it. Any ideas guys?
[IMG]20170613_201637 by 703 JRB, on Flickr[/IMG]
703JRB is offline
post #35 of 44 Old 06-21-2017, 11:23 AM
Double E
Double E's Avatar
Only thing I can think of...loosen nut, push tube in further, tighten nut.
I think I remember that when I did mine, there was a definite click to home position that indicated it reached where it was supposed to be...then I tightened the nut.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #36 of 44 Old 06-21-2017, 03:36 PM
mak_v8
When I changed mine, before installing the nut, I checked the internal O-ring, ....and I found that it was
I changed the O-ring before installing it; if I had used the original one, surely it would leak.
Looking at the picture, the hose seems to be in the correct position (you should have heard a "click"), so now you can't remove the hose.
The only thing that you can do is to brake the nut (cutting it in half), paying attention to not damage the hose, install a new one (it is available also on Amazon, I bought one for spare before installing the original one)and re-insert the hose.
Grand Cherokee WJ 4.7 V8 HO. m.y. 2002
mak_v8 is offline
post #37 of 44 Old 06-21-2017, 03:37 PM
mak_v8
When I changed mine, before installing the nut, I checked the internal O-ring, ....and I found that it was damaged.
The only thing that you can do is to brake the nut (cutting it in half), paying attention to not damage the hose, install a new one (it is available also on Amazon, I bought one for spare before installing the original one) and re-insert the hose.
mak_v8 is offline
post #38 of 44 Old 06-22-2017, 02:51 PM
Grippy0
Yep, break it loose, check the o-ring, and try to push the hose further into the nut.
I had to use thread sealer to stop mine leaking.
Grippy0 is offline
post #39 of 44 Old 06-22-2017, 07:38 PM
gatorgrabber
Can you tell me what you used for a replacement O-ring? As luck would have it, I just found the one on my hose was damaged when I pulled it to change out the radiator this afternoon. My plan was to head for the hydraulic supply house in the morning.
gatorgrabber is offline
post #40 of 44 Old 06-23-2017, 12:46 AM
sdg3205
sdg3205's Avatar
Your new hose should have come with new o-rings.
sdg3205 is offline
post #41 of 44 Old 06-23-2017, 05:06 AM
gatorgrabber
It was a new hose when the previous owner had it replaceded 2yrs ago. You can see where they nicked the O-ring during the install. No sense ditching a nice hose for something that simple.
post #42 of 44 Old 06-23-2017, 10:05 AM
sdg3205
sdg3205's Avatar
Ah, i see. Take the old ones to a good parts store. It's a start.
sdg3205 is offline
post #43 of 44 Old 06-23-2017, 11:24 AM
gatorgrabber
For grins, I called the dealer and asked what they would charge for the O-ring, if they had it. $8 (for one) and it would have to be ordered. Yea, that wasn't going to happen. So I dropped by the local hydraulic supply house who just gave me one (that fit perfectly) because they're both decent and couldn't be bothered to ring me up for 5 cents. And you wonder why folks don't like the dealers...
post #44 of 44 Old 06-29-2017, 12:11 PM
86cj74.2L
86cj74.2L's Avatar
I too wondered how the new style would seal when I replaced mine do to the constant weeping out the crimp. I even think there was a paper with it saying not to question the new style nut.
I slipped the nut over the pipe and held the line tight in the hole while I tightened the nut. No less for me at all.
86cj74.2L is online now
high pressure hose , hydraulic steering hose , power steering , power steering hose , steering , steering hose , wj
Power Steering Hose help- TJTony ZJ Grand Cherokee Forum 7 06-08-2009 10:29 AM
Power Steering Hose thegoat78 ZJ Grand Cherokee Forum 4 01-24-2009 03:57 PM
Power Steering Hose on 4.7 boundsmb ZJ Grand Cherokee Forum 7 01-06-2009 03:41 AM
4.7L power steering to fan controller hose ?? saki669 ZJ Grand Cherokee Forum 8 09-01-2007 08:05 AM
Power Steering Hose Double E ZJ Grand Cherokee Forum 2 06-30-2004 03:45 PM
