Please help diagnosing this grinding sound (probably) around tranny pan - JeepForum.com
 1Likes
  • 1 Post By Mr. Bitey
post #1 of 8 Old 10-01-2021, 08:44 PM Thread Starter
Jvanbev1
Wj Please help diagnosing this grinding sound (probably) around tranny pan
It happens when I give it gas (any amount of gas - louder with more gas). It sounds like it's coming from above the transmission pan. Any ideas what it could be specifically?
I used to only get this (or similar) sound when letting off the gas at >40mph, then going back on the gas. But now it is any time I give it gas. The only different thing is that I replaced the PCM.
Thanks
Jvanbev1 is offline
post #2 of 8 Old 10-01-2021, 09:35 PM
Mattyjm
Mattyjm's Avatar
It could be a cable rubbing against your driveshaft. I can't remember which one it is, but look for wear spots on your driveshafts and cables being close to them.
2004 Special Edition WJ. LOADED!
Mattyjm is offline
post #3 of 8 Old 10-02-2021, 07:43 AM
Delta0
Have you checked the lube in your transmission & transfer box for level & condition yet J?
Delta0 is offline
post #4 of 8 Old 10-05-2021, 10:00 PM
Bigrigr
Bigrigr's Avatar
My vote is something metal rubbing against the exhaust somewhere...
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #5 of 8 Old 10-05-2021, 10:10 PM
WJ60
WJ60's Avatar
Does it do it in park, or only when moving?
'77 Chevy C10 pickup
'01 WJ 60th Anniversary Edition
'13 Dodge Dart Rallye
WJ60 is offline
post #6 of 8 Old 10-06-2021, 07:52 AM
Mr. Bitey
Mopar Nut
Mr. Bitey's Avatar
Sounds like a heat shield on the exhaust to me. He is throwing revs at it while in park - can't be the driveshaft....
WJ60 likes this.
2004 WJ 4.7 N, daily driver
1967 Jeep J100 panel truck (a-rusted development)
1970 'Cuda, 340 4bbl (10.952et @ 123mph)
1972 Dart Swinger, Gen III 6.4l Hemi (11.223 @ 113mph)
1974 AMC Gremlin X, 440 6bbl (sold)
1975 Jeep Cherokee Sport 2-door (in progress)
Mr. Bitey is offline
post #7 of 8 Old 10-06-2021, 08:19 AM
WJ60
WJ60's Avatar
I'm going with Mr. Bitey on this one. I had a Chevy Blazer that had the same noise and it was the heat shield on the cat convertor.
WJ60 is offline
post #8 of 8 Old 10-06-2021, 11:56 AM
mak_v8
mak_v8's Avatar
I heard a similar noise with a cat whose internal ceramic part was in pieces; vibration of this pieces, knocking on the cat case caused a similar noise.
Mr. Bitey hypothesis is also possible.
Grand Cherokee WJ 4.7 V8 HO. m.y. 2002
mak_v8 is offline
