A-Pillar/Ditch Light Bracket Mount Options - JeepForum.com
 5Likes
  • 4 Post By Delta0
  • 1 Post By Bigrigr
post #1 of 7 Old 08-06-2021, 06:36 PM Thread Starter
carlsondrew3
Junior Member
carlsondrew3's Avatar
Wj A-Pillar/Ditch Light Bracket Mount Options
Hoping someone can shine some light, (pun intended) on how they mounted ditch lights on their WJ. As far as I can tell from endless Google and forum searches, most of the brackets that used to exist for the WJ are no longer sold. While I know there's some cheapo universal options that just clamp onto the hood, I don't really trust those to not wobble around or fall off on/offroad. Any recommendations/guidance is welcome!
2004 WJ 4.0L - "Jordan"
2.5" Lift, Rusty's Front Springs, BDS Rear Springs, FOX 2.0 BDS IFP,
IRO Custom Double Cardan Front Driveshaft
Check it out on RevKit and Instagram:
carlsondrew3 is offline
post #2 of 7 Old 08-07-2021, 01:53 AM
Delta0
Home Brewed,
WJeepster, GmanWJ, Bigrigr and 1 others like this.
Delta0 is offline
post #3 of 7 Old 08-08-2021, 07:15 AM
Bigrigr
Bigrigr's Avatar
Damn! thats cool....
Delta0 likes this.
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #4 of 7 Old 08-09-2021, 08:56 AM Thread Starter
carlsondrew3
Junior Member
Originally Posted by Delta0 View Post
Home Brewed,
Thatís pretty sweet. Wonder if something would work like that in the WJís housing despite it being a little crammed.
post #5 of 7 Old 08-10-2021, 08:49 AM
Delta0
Originally Posted by carlsondrew3 View Post
That’s pretty sweet. Wonder if something would work like that in the WJ’s housing despite it being a little crammed.
Yes, I wondered that. I also wondered about the light those 2 LEDs produced.
However, the idea of hanging a light off the external mirror seemed worth investigating.
The light claim 4000 Lumens.
https://www.ebay.co.uk/itm/294318048...YAAOSw-PBg7uJ4
Delta0 is offline
post #6 of 7 Old 08-10-2021, 09:11 AM Thread Starter
carlsondrew3
Junior Member
Looks like some Baja Designs pods so probably have some solid output as you mentioned. I wonder if the beam gets cut off as well from the hood. Might dissect my old non-heated mirrors and check it out to see if anything would fit.
post #7 of 7 Old 08-10-2021, 09:53 AM
GmanWJ
GmanWJ's Avatar
You could attach some rock lights for flood lighting ... would not be flush mount but they would be on. Not sure how much light you are looking for, these claim 3240 lumen.
https://www.roughcountry.com/led-rock-lights-70980.html
I hung a camera under my mirror. Had to drill a hole to run the wire but you can make it work, you can get power in there.
Details in part 6: https://www.jeepforum.com/forum/f310...l#post40997809
Turns out the camera is not so useful.
2.5" OME HD & Bilsteins
Dual Batteries
Aux Trailer Hookups (4awg charging & backup cam)
GmanWJ is offline
