PIcking up a new WJ on Saturday. - JeepForum.com
 1Likes
  • 1 Post By cruisingram
post #1 of 7 Old 11-14-2019, 04:07 PM Thread Starter
cruisingram
It's super duper clean throughout- claims to have a "head problem" which I am assuming is a valve seat drop? I am risking the purchase because it is super nice otherwise. I wish it were easier to swap in the 4.0! So, how often does the "head problem" turn into "the motor is toast"?
IturrGuate1975 likes this.
cruisingram is offline
post #2 of 7 Old 11-14-2019, 04:57 PM
X-Hibition
X-Hibition's Avatar
It sure looks good. Hopefully the price is right so you can factor in some engine work.
1999 Jeep WJ currently sporting four Yakima bars with many accessories...
X-Hibition is offline
post #3 of 7 Old 11-14-2019, 06:45 PM Thread Starter
cruisingram
If I have to replace the whole motor- I probably pay about what it is worth here- heads only- SCORE
post #4 of 7 Old 11-14-2019, 07:50 PM
smokeyyank
I swear that's someone's on here. Is it in Hawaii? If so pretty sure the engine was toast and due to the rebuild cost of getting the engine wasn't worth it.
If not am I'm just smoking the happy pipe too early. You honestly are better doing a full rebuild if you want to keep it. Yes cost is more. But the heads are a decent amount of work and not cheap to replace.
04 WJ, 4.7HO
3" IRO lift, fastman TB, 32s, lunchbox rear 242HD, 3" exhaust
smokeyyank is offline
post #5 of 7 Old 11-14-2019, 11:35 PM
[email protected]
It sure is nice looking. would be hard not to by it. I hope you solve your engine problem
post #6 of 7 Old 11-15-2019, 05:32 AM
HarryH3
No way to tell until you pull the heads. If you're lucky, a valve seat dropped, the engine ran like crap, and the owner parked it before major damage occurred. If not, then one possibility is that a piston met a valve. But some on here have just swapped in another piston/rod from a junkyard engine, then replaced the heads and been on their way.
I can assure you that you'll need a 5-gallon swear jar for the head swap. That engine was installed with a giant shoe horn, then covered with wiring and hoses. I despise doing anything under the hood of mine.
It's usually cheapest to order a complete head gasket gasket swap kit. It will come with head gaskets, intake gaskets, valve cover gaskets, etc. Basically, anything that has to come apart will come with a replacement gasket.
HarryH3 is offline
post #7 of 7 Old 11-18-2019, 02:35 PM Thread Starter
cruisingram
Thanks guys- I did think I told that person to try and log on here to ask about the jeep- so that person may have been on here.
