P0301/p0302 - JeepForum.com
post #1 of 9 Old 11-17-2019, 07:40 AM Thread Starter
ottoman89
P0301/p0302
I get these codes randomly. One will pop up and then go away for weeks, the other will then pop up and then go away weeks later too. I know they're "misfires" on cylinders 1 and 2?
I don't notice my Jeep running or starting rough. The gas mileage seems to be inconsistent. Is it as easy as bad spark plugs?
ottoman89 is offline
post #2 of 9 Old 11-17-2019, 08:31 AM
LuthWJ77
LuthWJ77's Avatar
Year and engine?
LuthWJ77 is offline
post #3 of 9 Old 11-17-2019, 08:46 AM
Shouden
2003 WJ
Could be:
Faulty spark plug or wire
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector
Burned exhaust valve
Faulty catalytic converter(s)
Running out of fuel
Poor compression
Defective computer
If it were my Jeep, I'd work it from cheapest to most expensive:
* put 1/2 a can of Seafoam in the gas tank
* Replace Oxygen Sensors (although usually this throws a separate code)
* Replace Spark plug/Coil
* Replace Fuel Injector
* EGR Valve
* Test for Compression
2003 Jeep Grand Cherokee Limited 4.7L HO
Shouden is offline
post #4 of 9 Old 11-17-2019, 08:48 AM
Shouden
2003 WJ
Oh.. you could also try reseating the coil pack.
Shouden is offline
post #5 of 9 Old 11-17-2019, 08:59 AM Thread Starter
ottoman89
It's a 2002 with 4.7m.
Is seafoam similar to HEET or completely different?
post #6 of 9 Old 11-17-2019, 09:30 AM
jtec
jtec's Avatar
2014 JK Wrangler
Did you use a scanner to get those codes?
The p0301 and p0302 are the only codes? Post ALL codes.
Start simple -
Seafoam not heat.
Spark plugs - 'read' the old plugs Wet Dry Black Tan damaged - Brand and type matter !
Cyl 1 and 2 are on different banks - might want to check connectors on injectors and coils.
I would also look at fuel pressure post PSI.
Ideally with a scanner we would look at live data - ECT, TPS, MAP, O2 sensor voltages,
Fuel Trim,
jtec is online now
post #7 of 9 Old 11-17-2019, 10:17 AM Thread Starter
ottoman89
Start simple -
Seafoam not heat.
Fuel Trim,
was not with a scanner. Just the old code reading trick. I should be able to get a scanner reading today. I'll keep you posted!
Thanks!
post #8 of 9 Old 05-14-2020, 05:48 PM
11B-33T
11B-33T's Avatar
Did the OP [ottoman89] ever find out what the issue was?
11B-33T
- 2005 Ford Escape XLT AWD
- 2004 WJ Grand Cherokee SE
- 2003.5 Mazdaspeed Protege
11B-33T is offline
post #9 of 9 Old 05-14-2020, 07:21 PM Thread Starter
ottoman89
Didn't realize it was my post until I saw your comment. I never did. It hasn't done it ever since!
