Overland Rock Rail j-nuts - JeepForum.com
 2Likes
  • 2 Post By HampshireWJ
post #1 of 11 Old 09-12-2021, 09:32 AM Thread Starter
andri
Does anyone know where I can buy the j-nuts that are used to fasten the Overland rock rails onto the body? Also, which specific shape and size are they? Mine were in such a bad shape that I had to drill them out, so I just threw them out a while back when I removed the rails.
I found out, when I removed them, that the rocker panels have big holes in them underneath. I was going to replace them with 2x6" steel, but I need to pass inspection this month, so I thought I'd just cover them up with the rock rails until I can get someone to sell me some steel.
andri is offline
post #2 of 11 Old 09-12-2021, 09:55 AM
Golden-Arm
Golden-Arm's Avatar
if you have rock rails, why even bother with replacing the rockers? a good set of sliders requires you cut out the rockers anyways.
mscdirect makes/sells j-nuts, cage nuts, etc.
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
post #3 of 11 Old 09-12-2021, 10:31 AM Thread Starter
andri
The rock rails reduce ground clearance and I'm not sure how well they'll fit, since I've trimmed the fenders a bit. I might have to shorten them to get things to align up, for nicer aesthetics. Also, I was thinking that I ought to cut out the rockers and line the inside with rust converter to keep the rest of the body from rotting away.
It seems that I can order j-nuts from plenty of online stores, but I still don't know which j-nut I should order. If anyone knows, it'd help a lot.
andri is offline
post #4 of 11 Old 09-16-2021, 11:04 AM
Delta0
Please will you explain why you think rust converter will stop rusting Andri?
Delta0 is offline
post #5 of 11 Old 09-16-2021, 02:13 PM Thread Starter
andri
I don't think that it will stop rusting. I would assume that it might slow down the spread from the area to which it is applied. Otherwise, what would be the point of applying it?
andri is offline
post #6 of 11 Old 09-17-2021, 10:54 AM
Delta0
Thanks Andri.
I don't know enough about Rust Convertor to answer your question I'm afraid.
Have you heard of Owatrol Oil?
https://www.owatroldirect.co.uk/product/owatrol-oil/
Delta0 is offline
post #7 of 11 Old 09-17-2021, 11:37 PM
HampshireWJ
HampshireWJ's Avatar
2003 WJ
M8 are the size used, they are also known as 'spire nuts' - well they are in England.
Delta0 and andri like this.
HampshireWJ is offline
post #8 of 11 Old 09-19-2021, 05:21 AM Thread Starter
andri
Thanks! It's also helpful to know an alternative name for them. Now I just have to figure out which shape I need to get. I guess I'll just order them in different shapes and see what fits.
andri is offline
post #9 of 11 Old 09-19-2021, 11:58 PM
HampshireWJ
2003 WJ
post #10 of 11 Old 09-20-2021, 10:49 AM
Delta0
Delta0 is offline
post #11 of 11 Old 09-21-2021, 04:52 AM Thread Starter
andri
Hey, thanks! I tried to find something on the rock rails on wjjeep.com, but I must have glanced right over it or searched for the wrong thing.
Here is a picture of the nut with measurements:
https://web.archive.org/web/20200217.../rail_unut.jpg
andri is offline
