Overheating...220+ - JeepForum.com
 3Likes
  • 1 Post By Soem0
  • 1 Post By Double E
  • 1 Post By anotherheep
post #1 of 14 Old 06-14-2021, 09:28 AM Thread Starter
Displaced in th
Overheating...220+
Well, summer is here and with it high air and road temps.
Unfortunately for me it is also meaning overheating.
Background, replaced thermostat this winter with a 195 unit. Ran fine all winter and spring, long haul, city, steep mine road, canyon passes at 7,000 feet, no problem.
Then the heat hit. So I turned on the A/C.
That seems to be a thing, A/C on, overheating. Turn the A/C off, it retreats very slowly.
Then yesterday (outside temp 101) it began to overheat even without the A/C on in city traffic. Once back on the highway it retreated to 200.
Where to start? Fluid is full, mix is 50/50. Clutch fan has no play or wobble. No fluid leaking from stat or water pump. WP has no play, wobble or evidence of seal leakage. Fluid is not dirty or discolored.
This Jeep is new to me, bought in December of last year so this is our first summer together.
Displaced in th is offline
post #2 of 14 Old 06-14-2021, 09:35 AM
Soem0
Soem0's Avatar
Typically you will see higher temps with the ac on. The condenser sits in front of the radiator. It is a good idea to make sure it is cleaned. Clean the fins as well as in-between the radiator and the condenser
Displaced in th likes this.
Soem0 is offline
post #3 of 14 Old 06-14-2021, 12:43 PM
jtec
jtec's Avatar
2014 JK Wrangler
a WJ I guess, might let us knw what year and engine.
jtec is offline
post #4 of 14 Old 06-14-2021, 01:05 PM
Double E
Double E's Avatar
If this is for a WJ, this sounds like a radiator that has become clogged and is not circulating well enough.
To verify, the next time it overheats, run the heater on full. This enables a secondary radiator of sorts that should bring the temp back down. That verifies your WP is circulating and that the temp can come down with cool air moving over some heater core fins but your radiator is not able to circulate well enough.
Figure this one out with a high priority to do it soon. Consider the all-aluminum option from ebay.
"We have it totally under control. Itís one person coming in from China. We have it under control. Itís going to be just fine." ~D. Trump, Jan 22, 2020.
Double E is offline
post #5 of 14 Old 06-14-2021, 05:55 PM Thread Starter
Displaced in th
Sorry, it's a 98, 4.3 V-8 Automatic.
post #6 of 14 Old 06-14-2021, 06:02 PM
anotherheep
Even if you fan clutch doesn't have wobble or play it could be on it's way out. Get the temp up up to where it's about to overheat and shut the engine off. The fan should stop spinning pretty quick if it's good. If it just continues to spin, the clutch is bad. If it is bad, that will also be effecting your a/c cooling
anotherheep is offline
post #7 of 14 Old 06-14-2021, 06:03 PM Thread Starter
Displaced in th
5.3 V-8
post #8 of 14 Old 06-14-2021, 06:36 PM
jtec
jtec's Avatar
2014 JK Wrangler
Posting in the WJ forum and claim this is a 98 jeep grand cherokee with a 4.3L or maybe a 5.8L - IDK something is not right.
jtec is offline
post #9 of 14 Old 06-14-2021, 07:19 PM
Golden-Arm
Golden-Arm's Avatar
sounds like he either has a typo, has no idea what engine he has, or worst of all, he has a chevy engine.
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
post #10 of 14 Old 06-14-2021, 09:33 PM
WJ60
WJ60's Avatar
Even a Chevy V8 4.3L would be wrong. The Chevy 4.3L was a Vortec 6 cylinder. Had one in my 2000 S10 Blazer.
WJ60 is offline
post #11 of 14 Old 06-15-2021, 07:30 AM
Dust Devil
Dust Devil's Avatar
GM actually made a 4.3l V8, a little baby LT-1 from back in the late 90s. It didn't stick around long because it wasn't any better than the 4.3 V6.
But that would be the weirdest engine swap I've seen in a long time.
Dust Devil is offline
post #12 of 14 Old 06-15-2021, 07:58 AM
Double E
Double E's Avatar
Displaced in th,
Go out to your Jeep, figure out what you have, then have someone else confirm it, then post a follow up note and delete the other posts.
Double E is offline
post #13 of 14 Old 06-15-2021, 08:50 PM
Golden-Arm
Golden-Arm's Avatar
5.3 should be a chevy ecotech engine.
the 4.3 should be a poncho.
both of these seem to be "unusual" choices for chrysler to be slipping into jeeps....
post #14 of 14 Old 06-16-2021, 07:21 AM
Delta0
Are Jeep gauges noted for their accuracy?
Delta0 is offline
