OK to tow WJ in neutral with tow dolly? - Page 2 - JeepForum.com
 1Likes
post #16 of 26 Old 10-05-2021, 05:14 PM
wjpaul
Again, I have towed my WJ for 10's of thousands of miles by following the procedure in the Jeep manual as I stated in my previous post on this thread. Key one click towards run, transmission in PARK (critical) and transfer case in Neutral. Yes, gears in the transfer case are turning, but they are in an oil bath so no lube issues.
02 GCL 4.7-QD-4.5" IRO LA lift-D44/ARB Locker-Bilsteins-HK hidden winch-JCR slider-Falken 32x10.5
wjpaul is offline
post #17 of 26 Old 10-05-2021, 08:16 PM
Bigrigr
Bigrigr's Avatar
As I understand it, WJpaul has nailed it here. But only IF you have the select-trac transfercase. QD II, and QTII both have the AWD system, and cannot be towed unless all for wheels are off the ground. This is due to the couplers in the transfer case, AND the clutches in the axles in the QDII. Select-trac should be a true neutral transfercase, with open differentials in most cases.
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #18 of 26 Old 10-05-2021, 11:37 PM
SoCal2004wj
SoCal2004wj's Avatar
If the transfer case is in neutral, then the coupler is not involved. The input/output shafts would just be spinning freely. As far as the QT II/QD II differentials, if turning was an issue, that would be a problem while driving (which it's not).
SoCal2004wj is offline
post #19 of 26 Old 10-06-2021, 07:42 AM
leadsled jeep
leadsled jeep's Avatar
Can you guys educate me further on transfer case in neutral but tranny in Park? I expected tranny in neutral as well. The rear driveshaft still turns when towing on all fours. That seems illogical but I am sure I just need to understand something better.
For a WEAK and IGNORANT people, SERF-dom is a Reward, not a Curse. W1CCW
leadsled jeep is offline
post #20 of 26 Old 10-06-2021, 08:36 PM
SoCal2004wj
The driveshaft turns because it is still connected to the rear wheels and differential. If the transfer case is in neutral, there is no transfer of power from the driveshaft(s).
post #21 of 26 Old 10-06-2021, 09:30 PM
WJ60
WJ60's Avatar
I would go by what your Jeep's owners manual says.
'77 Chevy C10 pickup
'01 WJ 60th Anniversary Edition
'13 Dodge Dart Rallye
WJ60 is offline
post #22 of 26 Old 10-06-2021, 11:34 PM
Bigrigr
Bigrigr's Avatar
We have had other posts about the 247 transfer cases being towed on a tow dolly with very bad results. The last one was a tow job by a towing company that had just lifted the front end and put the transfer case in neutral. Perhaps the flat towing would be OK, I dont know for sure. But the OP was asking about using a tow dolly specifically.
Bigrigr is offline
post #23 of 26 Old 10-07-2021, 04:41 AM
leadsled jeep
Good point, sorry OP about rabbit trail here. I have no plans to tow but was just trying to soak up your info guys.
post #24 of 26 Old 10-09-2021, 09:47 PM
SoCal2004wj
Good point, I forgot the original post was about towing on a dolly
post #25 of 26 Old 10-10-2021, 07:35 AM
jeepjeepster
You can flat tow (all four on ground) with any tcase. The issue comes when you have the front in the air and the rear is still turning.
The tranny must be in P so nothing in the trans is turning. The trans is lubed by the oil pump which is turned by the torque converter. If the engine isnt running, the tranny will not be lubed, so it needs to stay in P.
For the tcase, idk how the 247 is setup internally, so I cannot comment on it. Supposedly the rear output turns the oil pump in the 242, so in theory, it SHOULD be ok to tow with the rear on the ground and the front on a dolly, but DO NOT take my word....
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
post #26 of 26 Old 10-12-2021, 04:50 AM
V8GCZJ
Disconnect the drive shaft after it's on the dolly, Then use a ratchet strap to hold it in place. I did this with my ZJ.
V8GCZJ is offline
