Oil leak, and coolant - JeepForum.com
post #1 of 2 Old 04-15-2019, 08:14 PM Thread Starter
Mofugly13
Crawling around under the WJ, I have what I guess I would call seepage at the rear of the oil pan. Enough oil to look like it is ready to drip, but no actual drips. Weird thing is, thereís coolant there also. Not mixed, emulsified with the oil, but with the oil, with its green color visible. As if there are two leaks, one oil, one coolant, and they both accumulate in the same spot. But neither is enough to drip, as far as I can tell. Nothing on the ground underneath.
Itís a 4.0, so Iím guessing rear main seal for the oil. What about the coolant?
Sent from my iPad using Tapatalk
Mofugly13 is offline
post #2 of 2 Old 04-16-2019, 01:01 AM
sdg3205
sdg3205's Avatar
Pressure test the cooling system. You''ll find your leak.
sdg3205 is offline
4.0 Passenger Side Head Gasket Leak (External Oil) Crunchy XJ Cherokee Technical Forum 5 07-01-2018 09:29 PM
Detectives needed; ID this coolant leak source sdjp WJ Grand Cherokee Forum 32 05-26-2018 06:49 AM
Mystery coolant leak lfhoward KK Liberty Forum 2 03-15-2018 06:11 AM
coolant leak only on cold temp days 05TJWRANGLER WJ Grand Cherokee Forum 4 02-09-2018 04:57 AM
mystery coolant leak Skibum71 ZJ Grand Cherokee Forum 2 02-05-2018 02:24 PM
