OD off for this? - JeepForum.com
post #1 of 5 Old 10-14-2019, 10:14 AM Thread Starter
mtsgsd
OD off for this?
I've just moved to Pittsburgh, and the roads here are nothing but very steep inclines, serpentines, and hairpin curves! I've been turning off over-drive when I'm in the steep areas, thinking that will be better for the transmission. Does this sound like a good idea, or am I worrying about nothing?
1999 WJ 4.7 Powertech
Quadra-Trac II 45RFE P245/70R16 GG AT2
Akebono front calipers
mtsgsd is offline
post #2 of 5 Old 10-14-2019, 10:29 AM
007matman
If you were towing I might say it's a good idea. However, just normal driving I'd say take advantage of the OD as it'll automatically shift and you'll see better fuel economy.
Sent from my Pixel 3 XL using Tapatalk
007matman is offline
post #3 of 5 Old 10-14-2019, 10:58 AM
WJeepster
Thumbs up
Use OD off if you are climbing and want the torque converter to lock up in 3rd gear which would make it run cooler and thus better.
2001 WJ, 4.0, 242TC, tow, Akebonos, 94K
WJeepster is offline
post #4 of 5 Old 10-14-2019, 11:01 AM
Timo_90xj
Timo_90xj's Avatar
It's also a good idea to use OD off (or even third/ second gear depending on transmission) on longer/ steeper descends, gives you more compression braking and saves your brakes/ prevents them from overheating.
***Under construction***
Timo_90xj is offline
post #5 of 5 Old 10-14-2019, 12:06 PM Thread Starter
mtsgsd
So I guess I was on the right track then. Thanks guys.
mtsgsd is offline
