NP242HD loose rear output shaft bearing? Video, need help. - JeepForum.com
post #1 of 14 Old 05-29-2020, 03:15 PM Thread Starter
DoctorTim
DoctorTim's Avatar
Ive been having some noises in the back end so i opened up the tail housing of my NP 242HD and found this.... whats the fix? I didnt think bearings should be able to do this.
I also might as well install my HnT SYE that ive had on the shelf for months now.
Sorry for a short post, im on my phone. Need a fix for this soon as its my daily. Thanks.
edit: for those who cant see the video, the output shaft + bearing + snap ring is able to move axially about 1/8" within the output housing. Im also able to spin the output shaft bearing outer race withing the housing.
DoctorTim is offline
post #2 of 14 Old 05-29-2020, 03:40 PM
99wjtx
99wjtx's Avatar
I haven't watched the video so I can only guess what you're talking about. A loose rear output shaft could be a broken retainer/snap ring. With the tailshaft housing removed you should be able to verify that the main snap ring just in front of the bearing is still there. If it isn't, I think the entire main shaft assembly would eventually slacken up.
Rage! Rage against the dying of the Jeep.
99 WJ Limited 4.7/NV247
01 WJ Laredo 4.7/NP242
99wjtx is offline
post #3 of 14 Old 05-29-2020, 03:49 PM
Pine_Cat
Pine_Cat's Avatar
What were the noises? Squeeking? Clunking? Something else?
2017 JK
2016 MK- Murchison springs, ~1" BL, skinny 30s
2011 KK- H&R lift springs, OldManEmu shocks/struts, skinny 31s
2009 Sorento- H&R springs, ToyTec strut spacers, OldManEmu shocks/struts, 31s
2006 TJ budget LCG prerunner- see profile
2006 Trailblazer- EXT lift, Nth LJ 4.5" springs + Monroe rear coilovers, skinny 32s
1998 Durango- SuspMax & Roadmaster lifts, rear Truetrac, skinny 32s
Pine_Cat is offline
post #4 of 14 Old 05-29-2020, 04:33 PM Thread Starter
DoctorTim
DoctorTim's Avatar
I removed the tail housing. Snap ring is in place. The output shaft and bearing slides in and out axially within the output housing. The bearing also spins within the rear housing.
Clunks. See above.
post #5 of 14 Old 05-29-2020, 04:51 PM
99wjtx
99wjtx's Avatar
It's been five years since I tore one down. With my memory, it may as well have been a lifetime. There are other snap rings in there. Until someone else speaks up, maybe these pics will help you.
99wjtx is offline
post #6 of 14 Old 05-29-2020, 08:57 PM
99WJ01TJ
Just watched your video and the in and out movement is not supposed to be there. And by the reference point the bearing rave moves as you do it, it seems to move at in and out just as wide as a snow ring. Meaning that you seem to have lost a snap ring in the t-case. I have a 242wj case as well and will pull the tail housing off in the morning to check the outer bearing race play, but the bearings aren't a press in tolerance fit like other bearings so that may be normal. Also remember that steel bearing race and aluminum t-case expand at different rates like the 4.7 block and heads. It may just be that the case has expanded due to bearing becoming too hit and now it's permanent. Again, I'll check mine in the morning and report back, but it's not a press in type bearing.
99WJ01TJ is offline
post #7 of 14 Old 05-29-2020, 08:58 PM
99WJ01TJ
Sorry for the auto correct. Rave= race. Snow= snap.
99WJ01TJ is offline
post #8 of 14 Old 05-29-2020, 09:07 PM
99WJ01TJ
Me again. For those that can't/ haven't watched the video, the noise is a clunk as the output shaft moves back and forth(looks to be 1-2 mm of play). And he can (with some force due to the sound of the grunt I heard while he did it) move the outer bearing race left to right while I'm the t-case with the output shaft installed. I honestly never tried to spin an outer bearing race on a t-case after replacing one so who knows. As long as it's not causing any vibrations, this may be normal. But the play front to back on the shaft itself is definitely not normal.
99WJ01TJ is offline
post #9 of 14 Old 05-30-2020, 01:12 AM Thread Starter
DoctorTim
DoctorTim's Avatar
This talk of "lost a snap ring somewhere" has me concerned now that there might be a piece of steel floating around in a sea of oil and gears ready to grenade... So I did some more searching about that and found this video. I know its not the "HD" but it should be similar since its still a 242.
. I dont see any snap rings that would prevent the output shaft from moving axially a bit. It looks like the output bearing is what keeps the shaft from shifting axially (apart from the obvious gear assembly running into the case wall), but i'm not experienced with xfer cases so if anyone wants to object please do.
A schematic/drawing/blueprint of the 242HD would help a lot.
All videos like this the bearing is clearly a tight fit and even pre-installed in the rear housing for some SYE kits.
post #10 of 14 Old 05-30-2020, 01:19 AM Thread Starter
DoctorTim
DoctorTim's Avatar
The images you posted helped a lot thank you. This looks very similar to some other 242 videos i have seen. From what I can tell, if you remove the output housing (not the main housing rear half, im talking about the housing that the bearing is pressed into) the main shaft is able to slide in and out a little bit. This makes me thing that there isn't a lost snap ring and that the rear output housing or bearing is meant to keep the main shaft in place somehow. Let me know what else you can think of
Thanks
post #11 of 14 Old 05-30-2020, 06:12 AM
99wjtx
99wjtx's Avatar
Unfortunately, the cutaway view below is not a 242HD specifically. The diagrams are from the factory parts manual.
Behind the front bearing retainer (the cover that goes over the input shaft that interfaces with the transmission) there's a snap ring there too. It could be broken or missing. I believe this is number 3 in the first exploded parts view.
Also, the rear retainer has both an ID and OD retainer ring. The ID ring is the one clearly there in front of the bearing in my pictures and in your vid. The OD ring is behind the bearing and seats into the retainer housing. Unfortunately, the parts manual doesn't have an exploded view specifically of the HD. As you can see here, it shows the LD variant with the boot. Nevertheless, I believe the OD ring would be the same and install the same on both cases.
Since the rear bearing is basically held in place by retainer rings and apparently not a pressed fit into the housing, the fact that your bearing is spinning around can probably be considered a non-issue.
I have a 242HD in storage. I just checked to be sure and it's tight - no play whatsoever. I didn't check every shift position though I'm not sure that would matter.
I'm thinking if you go ahead and remove the rear bearing cover/retainer, you should be able to get a better idea of whether or not there's some lateral slop to go along with the axial play. Either way, if the previously mentioned retainer/snap rings are all in place as they should be then you're probably going to have to tear the case down completely to determine just what's come apart in there.
99wjtx is offline
post #12 of 14 Old 05-30-2020, 06:32 AM
Bigrigr
Bigrigr's Avatar
Thanks
I'm no expert on this transfer case. I own one, but have never had it apart yet. But i believe you are correct, in that the tail housing squeezes that bearing down when installed to limit that in and out movement. You say you are looking for a clunk? Maybe the chain is stretched a little and giving some clunk back and forth?
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #13 of 14 Old 06-05-2020, 04:47 PM Thread Starter
DoctorTim
DoctorTim's Avatar
Some of you may not like this. But until I have the time for a TC rebuild, I've JB welded a new bearing into housing and the play and noises went away. A proper fix would be to take it all apart, swap out bearings and chain, and put a new output housing on it so the bearing seats properly.
As for the snap ring concerns, I've spoken with someone who has rebuilt one and he confirmed that this bearing is what keeps the shaft from shifting the way shown in the video.
Problem solved errr... postponed..
post #14 of 14 Old 06-05-2020, 06:43 PM
Klarah523
Klarah523's Avatar
I was having a thought earlier today -- a lot of offroad kit comes with window stickers so people can pretend they're factory sponsored or something. I want JB Weld and Duck Tape window stickers
2000 WJ (Laredo w/ 4.0L) =|||||||=
Klarah523 is offline
