Noise from rear on a pit road - JeepForum.com
post #1 of 7 Old 07-02-2020, 05:46 AM Thread Starter
onaloto06
Hello,
I have a noise from rear, when my 02 Grand Cherokee 2.7 crd is on a pit road.
The shock absorbers are good. Everythink seems ok.
What would be the reason?
onaloto06 is offline
post #2 of 7 Old 07-02-2020, 07:46 AM
DJCantonGA
DJCantonGA's Avatar
Is is a 'clunk' sound? Check to make sure the shock bolts are tight. I think the upper nut is 80 ft/lbs and the lower is 85. When I installed new shocks, I thought they were tight, but it made a clunking sound.
2004 WJ-4.0 I6-42RE-278K-2.5" BB-265/65/17 Toyo Open Country 2 AT-Quadratec Hardrock Wheels
DJCantonGA is offline
post #3 of 7 Old 07-02-2020, 08:37 AM
Mattyjm
Mattyjm's Avatar
Push the body from side to side over the rear end of your WJ. Get it rocking pretty good and see if you hear a clunk. If you do, most likely, the upper A-Arm ball joint is shot.
2004 Special Edition WJ. LOADED!
2004 Rocky Mountain Edition. Froggy Bandit. Wife's Daily Driver. PRISTINE! Stock height and may stay that way.....
Mattyjm is offline
post #4 of 7 Old 07-02-2020, 01:09 PM
JoMc67
X10... it’s a good chance its the Rear Upper Control A Arm and Ball-Joint..
I was having the same “Clunk” noise from the rear when going over bumps until I replaced both parts.
Joe
JoMc67 is offline
post #5 of 7 Old 07-02-2020, 01:52 PM
Golden-Arm
Golden-Arm's Avatar
i'm going through my suspension, and found the a-arm, and the bushings to be suspect. since it's all right there, i'm just ordering a complete set-up from @Kolak , to go along with the rest of the suspension/lift upgrade. i would get a random repeating clunk on washboard tracks, but i couldn't pinpoint the source. pulling off the a-arm, i can see the end bushings are toast, and the ball joint on top of the pumpkin is gone as well.
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
post #6 of 7 Old 07-02-2020, 02:24 PM
JoMc67
Sounds good...l’m keeping my stock height, but I changed out all the Rear Suspension parts from @Kolak .
And, just because my WJ is 20 years old I’m also changing out all the Front Suspension and most Steering parts from @Kolak
JoMc67 is offline
post #7 of 7 Old 07-02-2020, 02:58 PM
DJCantonGA
DJCantonGA's Avatar
Originally Posted by JoMc67 View Post
Sounds good...lím keeping my stock height, but I changed out all the Rear Suspension parts from @Kolak .
And, just because my WJ is 20 years old Iím also changing out all the Front Suspension and most Steering parts from @Kolak
Same here. I'm replacing all the remaining steering and suspension parts soon. I figure with 16 years and 283K miles, why not. Should drive better.
