new wj questions - JeepForum.com
 5Likes
post #1 of 16 Old 04-04-2019, 05:43 PM Thread Starter
2oldjeeps
new wj questions
under dash fuses. how to drop the panel so i can get at them, cant stand on head, i can see the corner. i know its there but no way can i check them, help.
oil sender a z and orielly show a one wire sender for 4.7. its a gauge so whats up. havnt pulled it ,cold and rain.
44 degrees here, where is spring, global warming...
its the 04 4.7 spec addition. they claim its a different 4.7. idk 4.7's
Photoweborama likes this.
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #2 of 16 Old 04-04-2019, 07:32 PM
Photoweborama
Photoweborama's Avatar
There is no easy way to see the fuse panel...
Sent from my iPad using Tapatalk
Photoweborama is offline
post #3 of 16 Old 04-04-2019, 07:40 PM Thread Starter
2oldjeeps
so its useless huh,no way to use it. cant loosen it somehow?
knee bolster remove? i gotta try...
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #4 of 16 Old 04-05-2019, 09:03 AM
jtec
2014 JK Wrangler
I can get to it and I am a big old man. there is a plastic cover that snaps off.
door open and kneeling should be visible - would a legend of fuses help?
Gotta ask what you looking for?
I see a 1 wire Oil Pressure sensor (2wire connector uses only 1) at oil filter.
Anyway I am in 04 OEM manual for something else If I can help let me know.... it will be open for this morning.
jtec is offline
post #5 of 16 Old 04-05-2019, 09:18 AM
ksinglxj
ksinglxj's Avatar
just pull on the plastic cover and it comes right off. inside of the plastic cover tells you which fuse is for what. have to kneel down and bring a flash light, but its not inaccessible.
ksinglxj is offline
post #6 of 16 Old 04-05-2019, 09:24 AM
Photoweborama
That is true, the cover does have a diagram showing the layout...
But Iím a short Chinese guy with small fingers... I still almost have to lay on the floorboard to do anything with it... heaven forbid the flasher relay!!! That was a nightmare I donít wish to have to do that again! :lol:!!
Whenever possible I call my son, Cameron... heís taller than me, but skinny... heís almost 21, so he thinks everything is easy... I get him to pull the fuses for me...
99sajeep, jtec and f0xtrawt like this.
post #7 of 16 Old 04-05-2019, 10:46 AM Thread Starter
2oldjeeps
i see only a big knee bolster under the steering. the fuse block is under the dash.
oil is a gauge, not a light, is one wire ok. ?
want to look at fuses b4 door wires for locks and windows.
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #8 of 16 Old 04-05-2019, 11:06 AM
jtec
2014 JK Wrangler
One wire is what 04 oil sensor wiring has.
jtec is offline
post #9 of 16 Old 04-05-2019, 12:12 PM Thread Starter
2oldjeeps
ok, tnx,ill get dirty soon!! looks messy up there...
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #10 of 16 Old 04-05-2019, 01:48 PM Thread Starter
2oldjeeps
what kind of cars are you guys talking about??? mine is a jeep,wj,04,special edition,white/blk leather!! THERE IS NO PLASTIC PANEL THAT COMES OFF!!! a LARGE KNEE BOLSTER FROM THE DOOR TO THE CENTER,wont budge,one screw on upper left. i thought 2 bolts might be involved ,wrong but i tried all tools i have, none fit! either small or big from 5/16 to 10 mm!! none fit!!
if i tug on it ,it feels like it will break first,dont know whats behind it
if i do have a blown fuse ill never know.
my worst day with jeeps...i give up...
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #11 of 16 Old 04-05-2019, 02:00 PM
jtec
2014 JK Wrangler
Yogi-4 likes this.
jtec is offline
post #12 of 16 Old 04-05-2019, 02:56 PM Thread Starter
2oldjeeps
Amazing!!! normal people would be lost,go to dealer to have fuse done!!!
ill toss the 10 mm bolts...and drop the fuse panel if possible.
tnx again.
i never would have dreamed this...
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #13 of 16 Old 04-05-2019, 03:29 PM Thread Starter
2oldjeeps
7 bolts/screws into it,wanna see the relays. saga continues sat morn.not loose yet..
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #14 of 16 Old 04-07-2019, 09:54 PM Thread Starter
2oldjeeps
recap, got windows and locks fixed, door wires and i posted details of the "saga" separetly.
got the "one wire" sensor changed, now have oil pressure!! actually shows for real...
still havnt got into pass door for ? rke short range problem..later
tnx all for help
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #15 of 16 Old 04-17-2019, 07:24 AM
NYCherokee
The flasher relay was my first job on my Jeep. And yes that thing is jammed in there! Took about an hour. Was so hyped when it was completed.
What other common issues are dealt with the fuses near the flasher? Even though the other fuses seem self explanatory. Do they do anything other then what the title is?
https://www.cherokeeforum.com/attach...0-13-56-28.jpg
NYCherokee is offline
JK Newby Questions NumbLost JK Wrangler Technical Forum 17 03-26-2018 08:39 AM
a few questions before buying an XJ MaraXJ XJ Cherokee Technical Forum 5 02-21-2018 10:42 AM
TJ Brute suspension/frame questions TJsRedTJ TJ Wrangler Technical Forum 2 01-11-2018 10:27 AM
How cold is too cold? Heat questions jonnygranada YJ Wrangler Technical Forum 12 01-03-2018 01:04 PM
Upgrading my Dana 30, comes with questions. Towny72 YJ Wrangler Technical Forum 18 12-29-2017 06:53 AM
