New Starter - JeepForum.com
post #1 of 6 Old 05-31-2020, 07:54 PM Thread Starter
OHOHgreyWJ
OHOHgreyWJ's Avatar
New Starter
Stock starter just recently went out on my 4.7
Open to suggestions on which aftermarket brand has the best reputation. Or if it matters at all?
OHOHgreyWJ is offline
post #2 of 6 Old 05-31-2020, 08:49 PM
nickb123
I used a Mopar starter from the dealer, it was about $130 if remember right. I work at a shop and haven't had much luck with aftermarket starters.
nickb123 is offline
post #3 of 6 Old 05-31-2020, 08:55 PM Thread Starter
OHOHgreyWJ
OHOHgreyWJ's Avatar
Thats what I was leaning towards. Just wanted to run it through the forums and see if anyone had luck with any other brand.
Much appreciated
post #4 of 6 Old 05-31-2020, 11:15 PM
2oldjeeps
had a bad new reman. paid the price for "new" new from napa.
it actually had paper work with mfgr test specs.
such a pia to change, its worth it...
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #5 of 6 Old 06-01-2020, 05:13 AM
Klarah523
Klarah523's Avatar
Had bad luck with reman'd starters, alternators, and worst (obviously doesn't apply to WJ's) carburetors. I had some clunkers that was the only source of parts for, though. Didn't seem to matter where I got them either: Checker, NAPA, AutoZone.
If you can get new I would, and if you can stick with Mopar.
2000 WJ (Laredo w/ 4.0L) =|||||||=
Klarah523 is offline
post #6 of 6 Old 06-01-2020, 06:41 AM
Double E
Double E's Avatar
I've had good luck with the aftermarket units. I've swapped 3 of them, each in a different WJ. 2 were from Adv Auto. The 3rd NAPA unit looked the best of them but they all performed perfectly. My thinking is that the swap is easy enough that I'd rather have the lifetime warranty than go back with the much more expensive mopar unit that's known to fail albeit after 16 or more years...
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
