New rear axle seal leak, new axle next? - JeepForum.com
post #1 of 12 Old 06-17-2019, 10:34 PM Thread Starter
mustang67ford
Got about 176K on my 99. Started to get a leak at the rear passenger axle seal so had my mechanic replace it along with the bearing. Its been about a week and the seal is still leaking. He is thinking of trying another seal, but the brand he used is a good brand, skf from NAPA I believe. Is it possible the axle could have gotten a groove in it allowing fluid to leak past the seal? I'm guessing if so I might need to get a new axle as well.
mustang67ford is offline
post #2 of 12 Old 06-17-2019, 11:15 PM
97Mule
97Mule's Avatar
He should have seen a groove. Have him replace seal for no labor!
97Mule is online now
post #3 of 12 Old 06-18-2019, 01:43 AM
GmanWJ
GmanWJ's Avatar
I replaced both of my rear axle seals/bearings with National from O'Reilly. One leaked. Replaced that one with a Timkin that I bought from Summit, which is holding. So maybe you should give the Timkin a try. Worth a shot.
ok mostly just repairs, but we are closing in on a lift
GmanWJ is online now
post #4 of 12 Old 06-18-2019, 11:39 AM Thread Starter
mustang67ford
Thanks for the info, he is a good guy. Im sure he will treat me right. Just trying to figure out the next steps. Ill suggest the timkin. If i need a new axle. Where is a good place to go for that?
post #5 of 12 Old 07-30-2019, 02:28 PM Thread Starter
mustang67ford
Do you have a part number for the timkin seal? Summit is not showing one for the rear axle? Thanks
post #6 of 12 Old 07-30-2019, 02:56 PM
GmanWJ
GmanWJ's Avatar
I seem to recall searching a bit to find them, but these are what I installed.
Bearings: https://www.summitracing.com/parts/tmk-set31
Seals: https://www.summitracing.com/parts/tmk-2146
post #7 of 12 Old 07-30-2019, 03:08 PM
FanTech
First thing to look at (if it hasn't been done already) is to make sure the breather vent is clear. Those axle seals are not measure to be pressurized. As the diff heats up, air inside will expand causing a build up in pressure.
FanTech is offline
post #8 of 12 Old 07-30-2019, 03:17 PM
CarlJH
2003 WJ
Rockauto has it as 2146
CarlJH is offline
post #9 of 12 Old 07-30-2019, 05:34 PM
Oktavius
I've had axle seals not seal to the axle tube. I use a light coating of RTV on the OD of the seal to help seal to the axle tube. Might be leaking there and not from the seal/axle interface.
Oktavius is online now
post #10 of 12 Old 07-31-2019, 11:40 AM
xcaliber81
xcaliber81's Avatar
I'm about to do rear bearings and seals should I be worried about using skf seals?
xcaliber81 is offline
post #11 of 12 Old 07-31-2019, 04:14 PM Thread Starter
mustang67ford
Not sure what the issue is with my axle yet. My mechanic is getting the new seal before pulling it apart. Could be the seal or could be the axle. Not sure what to do if it is the axle. Also, this appears to be the first time seal and bearing was replaced.
post #12 of 12 Old 07-31-2019, 05:22 PM
xcaliber81
xcaliber81's Avatar
My rear end vibrates and its definitely the bearings
