New Member - and question from Australia - JeepForum.com
post #1 of 13 Old 08-19-2019, 06:14 AM Thread Starter
Skaliwagz
G'day guys and gals, I'm a new member and yup from Oz.
I have a 01 4.7 grand cherokee and have done some work to her and she is a beaut.
Any way long story short the head gaskets went so I've rebuilt her from the ground up all new parts sourced from mopar from rockauto and the states...as prices here in Aus will make any millionaire broke.
But now she won't start it cranks but no start or running. Everything has been tested and timing is correct. The obd2 gets power but won't read the pcm so I suspect bad pcm.
My question is .... is it possible to put a 05 4.7 pcm in if I have the skiM, locks ect?
I also get that the plugs to the pcms are different so I would need to research the pins diagrams to get the correct wires to corresponding pins on the 05 pcm ... is this possible or a waste of time?
01-04 pcms here are not common and to re-program costs far more than the module itself. Naturally I will do that if I have too I just thought i would pose the question about an newer pcm.
Many thanks in advance.
Skaliwagz is offline
post #2 of 13 Old 08-19-2019, 08:53 AM
JGCJeep
My OBD2 won’t read the codes without the engine running.
JGCJeep is offline
post #3 of 13 Old 08-19-2019, 09:47 AM
jtec
jtec's Avatar
2014 JK Wrangler
Jumping to conclusions without check anything....damn sheep shaggers....
lets back burner the PCM concerns and ideas.
When you turn the key to RUN/START will the CEL come on for @3 seconds then go out?
Did you try thr key on off trick to see if it retrieves codes?
Am I correct engine cranks no start?
What is fuel pressure - use a gauge....
When key moved to RUN - might need 2 people to check as it may only have 3seconds of power is there 12v
At injectors?
At coil?
jtec is offline
post #4 of 13 Old 08-19-2019, 09:57 AM
jtec
jtec's Avatar
2014 JK Wrangler
At injectors?
At coil?
jtec is offline
post #5 of 13 Old 08-19-2019, 10:15 AM
HarryH3
Another member just had the same thing happen. Crank, but no start after a rebuild. Jeep PCM's are insanely sensitive to having all of the proper grounds. He was able to find the problem by following the advice in this thread: https://www.jeepforum.com/forum/f310/...-info-4192594/ He found a loose ground, fixed it and the Jeep fired right up. :-)
HarryH3 is offline
post #6 of 13 Old 08-19-2019, 12:37 PM
oldRodney
Originally Posted by HarryH3 View Post
Another member just had the same thing happen. Crank, but no start after a rebuild. Jeep PCM's are insanely sensitive to having all of the proper grounds. He was able to find the problem by following the advice in this thread: https://www.jeepforum.com/forum/f310...-info-4192594/ He found a loose ground, fixed it and the Jeep fired right up. :-)
welcome to the forum....
yes the fellow harry is referring to is ME... I had a young person help me with the install,
we had to replace one motor mount. you have to be extra careful with the "ground bolts" as they appear to be the same as the "motor mount" bolts. BUT in reality the ground bolts are shorter than the motor mount bolts... when they get mixed up thats when the problem starts.. the motor mount bolts when installed in the ground holes will bottom out and not fully cinch up the ground wires... I was having the exact issues you are having, all the gauges read zero and she would not fire up... once I located and fixed the ground issue, she runs beautifully ... it has been over a week and we have put more than 200 miles on her, always starts right up... check the G103 ground wires...[passenger side behind the 02 sensor]. there is a two wire connector and a thick, one wire attatched to the ground hole.... hopefully this info will help you out..
good luck my friend...
oldRodney is offline
post #7 of 13 Old 08-19-2019, 03:51 PM
LumaWJ
On the left side, above pcm there is very important plug, check if this is connected fight....
JGC 4,7l
Wrangler YJ
LumaWJ is offline
post #8 of 13 Old 08-19-2019, 07:13 PM
oldRodney
the short and sweet answer is NO.....
post #9 of 13 Old 08-20-2019, 06:05 PM Thread Starter
Skaliwagz
Thank you all for your replies. I will give the suggestions a try definitely take a good look at the grounds again.
post #10 of 13 Old 08-20-2019, 08:59 PM
CarlJH
2003 WJ
If the engine ran before you took it apart and you didn't short the battery in any way when you disconnected it then the PCM should be ok, there are grounds on both sides of the block, coil hold down bolts on 7 and 8 to firewall by brake booster and exhaust hanger on bell housing to side frame, but I don't think that one does much as mine was totally missing and everything still worked.
CarlJH is offline
post #11 of 13 Old 08-22-2019, 12:10 AM Thread Starter
Skaliwagz
Hi guys that's for the advise.
I've finally gotten around to rechecking all the grounds again including the 2 on each side of the block.
I have cleaned them all with very fine sandpaper so now shiny on the eyelets and mounting points.
Unfortunately no change to my problem.
post #12 of 13 Old 08-22-2019, 05:45 AM
CarlJH
2003 WJ
next step is to check whats missing, spark or fuel, then power and grounds to the PCM, if you don't have the FSM, there's an online one here.....
https://cardiagn.com/2000-jeep-grand...ring-diagrams/
a quick look and I think connector C102 could be the problem as thats where the coils and injectors get power from.
CarlJH is offline
post #13 of 13 Old 08-25-2019, 12:07 PM
Barber613
Check the crank shaft sensor and make sure you plugged it back in
Barber613 is offline
