Need help buying 16x8 wheel not sure on offset - JeepForum.com
post #1 of 14 Old 09-09-2020, 09:35 PM Thread Starter
iaintslow
hello everyone this is my first post and i did search but nobody talks about offset.
Im looking to get 16x8 soft8 steel wheels and i know i need 4" or 3.75" back space but what about offset? I fount 3.75 back space with -19 offset would that stick out like crazy passed fenders? I will get 4" lift but i jist want my wheels not to stickout too much. I also see 16x7 with 0 offset and 4" back space but im confused now and not sure what to get.
iaintslow is offline
post #2 of 14 Old 09-09-2020, 09:51 PM Thread Starter
iaintslow
Sorry 16x8 -12 offset not -19
post #3 of 14 Old 09-10-2020, 04:49 AM
62JEEP
62JEEP's Avatar
2003 WJ
265/65R17 with -12mm offset
My wheels are metric sizes (and slightly different size to yours) but that won't make much difference to your deciding to switch to a -12mm offset. I run 17" Fuel Beasts with a -12mm offset. That's the maximum offset I'm allowed to run here in New South Wales (ie. a maximum offset for both wheels combined of 25mm or 1"). I've had them on the car with a 2" lift for a year now and use the vehicle around town and off-road.
Handling? It handles like a tractor - but I've got a lot of iron work plus winch up front!
Appearance? I'm really pleased with it - the tires protrude beyond the body-line by about 1" to 1.5" either side and I've fitted a set of ebay special flares, front and back, to make it legal. Check the before and after pics.
62JEEP is offline
post #4 of 14 Old 09-10-2020, 05:21 AM
Tarneg
backspace is WMS to back bead of the tire and offset is the WMS to centerline of the rim. taking either of these you can measure how far to the outside of WMS the wheel will stick and then you can approximate the tire bulge on top of that. as for on the vehicle that will take someone with one to tell ya or straight edges and measuring
Tarneg is offline
post #5 of 14 Old 09-11-2020, 05:39 PM
Spinifex
Spinifex's Avatar
Urgh, don't miss that at all
The 3.75" backspaced wheels will sit further in, but I think the Factory backspacing is ~4-4.5 so you should be OK. Not sure how you can have 4" backspacing and 0 offset on a 7" wide rim? I would think the offset would need to be 12 or the wheel 8". (no expert here).
Spinifex is offline
post #6 of 14 Old 09-12-2020, 04:43 PM
eljeepwj
2003 WJ
Factory backspacing is 6" for the 16x7" wheel or 6.25" for the 17x7.5". The larger the backspacing the more from the hub the wheel sits inward.
Link:http://www.wjjeeps.com/wheels.htm
A 4" backspacing sits 2 inches wider than a 6" backspacing.
I am running 16x8" Jegs D windows with a 4" backspacing and -12 offset. They stick out for sure but i dont think it looks too wild and still tucks into the fender well at flex. I can post a pic later if it helps. Link: https://www.jegs.com/i/JEGS/555/681032/10002/-1
Good article here to help you decide.
https://www.4wheelparts.com/the-dirt...BoCpKwQAvD_BwE
2003 Jeep WJ 4.0 2in IRO w Procomp Es9000 on d windows 245/75/r16 DD
eljeepwj is offline
post #7 of 14 Old 09-12-2020, 06:23 PM
2oldjeeps
2oldjeeps's Avatar
my brain cant handle those TWO measurements. why not just one or the other?
99wj, 150,000 miles
00xj ,189,000 miles
10hummer3,76,000 miles
98xj, 133,000 miles
2oldjeeps is offline
post #8 of 14 Old 09-13-2020, 03:11 PM Thread Starter
iaintslow
So i just ordered 16x7 with 0 offset, i don't have a lift yet , once i get them here i will throw one on to see how it looks and decide on the tire size and if i need a lift. Anybody know if original tpms sensors can work with steel wheels?
post #9 of 14 Old 09-17-2020, 07:10 PM Thread Starter
iaintslow
SO here it is 16x7 with 0 offset, just perfect almost flushed with the body. Looks like i will need a lift after all, you guys think 255 70 16 will hit fenders without the lift? Will 2" bb lift work with 255 or 265 70? or i need 4" lift for that?
Thanks
post #10 of 14 Old 09-18-2020, 01:33 AM
Tarneg
ya just need to measure that on your jeep my dude. put the weight on the suspension for that rim and measure from the center outward and account for turning also.
Tarneg is offline
post #11 of 14 Old 09-18-2020, 08:12 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by Spinifex View Post
... Not sure how you can have 4" backspacing and 0 offset on a 7" wide rim? I would think the offset would need to be 12 or the wheel 8". (no expert here).
Offset measures to the bead seat.
Backspacing measures to the outer edge of the wheel.
The bead seat area is 1/2" thick.
Wheelin98TJ is offline
post #12 of 14 Old 09-18-2020, 08:28 AM
dbtong
Thanks
Thanks for posting the pics. Does anyone know if running the stock 245/70 tire on this wheel spec works as a daily driver without issue?
Dave
2000 WJ Laredo 4.0
dbtong is offline
post #13 of 14 Old 09-18-2020, 06:50 PM Thread Starter
iaintslow
All depends on how much clearance you have between the tire and fender, thats my problem right now i dont know how much tire travels up on big bumps, im going with 2" bb lift to be safe and 255 70 16 tire, even tho stock height looks like there is plenty of room i been told by them wheel manufacturer that i should get a lift.
post #14 of 14 Old 09-22-2020, 11:15 AM
BlueOffroader
BlueOffroader's Avatar
I purchased 16X8 0-offset from Rough Country. I put on BFG KO2 32s ( 265/75 R16) . I have 4" lift and still had to trim my from bumper, otherwise won't fit. Rear bumper no problem. If you went with same size as mine, 2" BB then you should be fine with minimal trimming. Attached the pics so you can see. WIth 255 /70 16, i dont believe you need a lift for that. Its only half inch taller than stock.
BlueOffroader is offline
