Need heat-limited- passenger side - JeepForum.com
post #1 of 3 Old 11-14-2019, 07:26 AM Thread Starter
birmingplumb
Must be a way to manually move the blend door lever to "heat" after cutting into the duct. How? auto temp control limited heat on drivers side / cold air on passenger side 300k dont want pull dash. Auxillary heater?
birmingplumb is offline
post #2 of 3 Old 11-14-2019, 09:15 AM
jtec
jtec's Avatar
2014 JK Wrangler
read
https://heatertreater.net/jeep-grand...98-04#dualzone
there is another provider BUT I can't remember the link.
jtec is offline
post #3 of 3 Old 11-14-2019, 11:38 AM
Uniblurb
Uniblurb's Avatar
The way the WJ HVAC box is designed believe it would be super difficult to connect a manual control cable/lever to the blend doors to open/close them. And even with the current manual system the blend door(s) are electric motor/servo controlled just like the AZC (auto zone control) system.
Below are some tech tips from the blendoorstore on troubleshooting your HVAC system.
http://blendorstore.com/tech_tips
There's a diy video below on replacing the blend doors. And while they don't say what brand of doors they are they're the Dorman blend door kit which turns dual-zone control into a single control.
https://www.jeepforum.com/forum/f310...l#post40247513
The post following the above one is where I installed the blendoorstore dual-control blend doors. Was still able to have separate control for the driver and passenger side instead of just a single control for both. Good luck.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
