Mysterious leak; appears to be coming from a small opening. What is it? - JeepForum.com
 5Likes
  • 2 Post By 97Mule
  • 2 Post By DJCantonGA
  • 1 Post By Uniblurb
post #1 of 14 Old 05-23-2019, 06:51 PM Thread Starter
escher24
escher24's Avatar
I finally got my 2001 Jeep Grand Cherokee (WJ) home, and I've been working on fixing a lot of its basic functionality problems. However, after I filled up the transmission fluid, I saw a leak coming from under the car. After placing plain white printer paper down there and carefully sniffing, it seems like plain water rather than transmission fluid. I'm not a car expert at all, but I'm thinking it's some kind of coolant/radiator leak. I tracked the source of the leak to a mysterious opening under the hood (pic included). I have no idea why there's an opening here, nor what it does or why it's important. I feel like there's a hose or something that's supposed to attach to it. What's going on here, and is the leak anything to worry about?
escher24 is offline
post #2 of 14 Old 05-23-2019, 07:20 PM
97Mule
97Mule's Avatar
AC condensation drain..... Normal .
Uniblurb and jayheats like this.
97Mule is online now
post #3 of 14 Old 05-23-2019, 08:03 PM Thread Starter
escher24
escher24's Avatar
Good to know. Thank you!
escher24 is offline
post #4 of 14 Old 05-24-2019, 03:56 AM
JeppeWJ
Hey I was looking for the ac-drain on my car! Is that the 4.7 engine?
JeppeWJ is offline
post #5 of 14 Old 05-24-2019, 06:43 AM
97Mule
97Mule's Avatar
Thats the 4.0...... The ac drain is in the same area on all wj's!
post #6 of 14 Old 05-24-2019, 07:16 AM
DJCantonGA
DJCantonGA's Avatar
Your blinker fluid is leaking out
97Mule and OldGreyV8 like this.
DJCantonGA is offline
post #7 of 14 Old 05-24-2019, 02:54 PM
Mofugly13
You should get yourself a short length of tube that will slip over that to drain it a little further from the firewall. I think it’s 1/2”. A 6” piece of vacuum line or coolant line will do it.
The reason I suggest this is that the water that drips out of that tube can blow back to the firewall and end up collecting on the passenger side floor. Mine was creating quite a puddle. I thought it was my sunroof drain line because those seem to be a common cause of water on the floor. So I did all the recommended fixes for that and still had water collecting.
Then I ran across an obscure post here on the forum that said to route that drain a little further from the firewall, so I did, and that did the trick.
Sent from my iPad using Tapatalk
Mofugly13 is offline
post #8 of 14 Old 05-24-2019, 03:07 PM
Uniblurb
Uniblurb's Avatar
Lol DJCantonGA.
Below is a video I've watched before of a guy cleaning out his WJ AC drain on the outside of the firewall. Pretty extreme to run a hose in the HVAC box then get under there to take a video under a waterfall! Ha!
https://www.youtube.com/watch?reload=9&v=iMYOZ__HoBg
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
post #9 of 14 Old 05-24-2019, 03:58 PM
DJCantonGA
DJCantonGA's Avatar
I put a piece of 90° rubber tubing on mine and the turn down part goes 6" or so. I heard where sometimes the wind would blow the condensate back inside, possibly causing a leak.
@Uniblurb , I saw that video! Good on him, but I'm not going that far! I used a small pick tool (carefully) to make sure there wasn't any debris inside though.
post #10 of 14 Old 05-24-2019, 10:21 PM
Uniblurb
Uniblurb's Avatar
@DJCantonGA , that looks like a pretty good fix to put a 90* rubber hose on the end of the AC drain. I too have heard the airflow can push the water back on the outside of the drain tube then if your seal is bad at the firewall the water will end up on the passenger floor.
Bet the below Dayco 80394 hose with 90 degree elbow would work and it's 1/2" ID. It sells a little cheaper at Advance and Autozone for $8-9.
https://www.amazon.com/Dayco-80394-M.../dp/B000C0YPZ4
We're pretty lucky we can even get to the end of the drain tube on our WJ's. Check out this write-up I did for my ZJ to route the AC drain water through the wheel well and used the above Dayco hose. Real nice of Jeep to bury it in the frame so water will rust the frame out!
https://www.jeepforum.com/forum/f13/...te-up-3412082/
DJCantonGA likes this.
Uniblurb is offline
post #11 of 14 Old 05-25-2019, 07:48 AM
DJCantonGA
DJCantonGA's Avatar
Ha, I found your thread about the ZJ ac drain when researching the cause of my WJ leak! One of the reasons I joined JF!
That hose you linked looks just like what I used. I had one in the shop that fit. It was a tight squeeze on the original spout, and I just sealed around it with silicone. My leak turned into a 3 month nightmare. My love for the WJ kept me going at it until I finally found the source (passenger side moisture/vapor barrier wasn't sealed at the bottom, allowing water to intrude over the door seal).
But now I have new seals all around, a resealed windshield (it was leaking, but not bad), and new window trim lol.
They made the ac drain a bear to get at on your ZJ!
post #12 of 14 Old 05-25-2019, 09:56 AM
blueseasons
JeppeWJ: If you find yours let me know. I have been looking for my AC drain for 4 years and cant find it. I'm not stupid or blind. If it was easy, I would have seen it by now. 2000/4.7
blueseasons is offline
post #13 of 14 Old 05-25-2019, 10:01 AM
JeppeWJ
blueseasons .. wow sounds like it's not easily accessible on our 4.7 engines .. Now I know where to look and will let you know if I find it .. lol
JeppeWJ is offline
post #14 of 14 Old 05-25-2019, 09:59 PM
97Mule
97Mule's Avatar
When you guys "find" the drain , just slip a scrap 90* hose on it.
There usually free at the bone yard!
My wife’s Renegade has a small leak... so they give her this as a loaner... Photoweborama Grand Cherokee General Discussion 4 04-17-2019 09:27 PM
My JK Roof Leak Saga rsurran JK Wrangler Technical Forum 26 01-02-2019 08:07 AM
small leak on front axle drive shaft by wheel Tony01 YJ Wrangler Technical Forum 9 09-13-2018 08:18 AM
Small Evap Leak bow6x6 WJ Grand Cherokee Forum 9 05-15-2018 09:09 AM
small gas leak sman26 Jeep CJ Forum 10 12-05-2017 05:09 AM
