LR window goes down but not up - JeepForum.com
post #1 of 37 Old 03-28-2012, 07:09 AM Thread Starter
cj7guy
It's now all the way down....but won't go up.
Is this a common problem? Is there a fix...or do I just need a new regulator?
Thanks,
Jon
07 JKU - 6spd - LSD rear
cj7guy is offline
post #2 of 37 Old 03-28-2012, 07:48 AM
peytonimor7
peytonimor7's Avatar
Not very common I don't think. Most likely a new regulator will be needed, or there may just be something in the way of the window. Take the panel off and you'll find out.
l 04 WJ l OME HD+3/4" spacers l Bilstein 5100 l 245/70/17 Firestone M/Ts l IRO A-Arm & CAs F & R l
peytonimor7 is offline
post #3 of 37 Old 03-28-2012, 08:11 AM
jahcure
The cable mechanism may be damaged
jahcure is offline
post #4 of 37 Old 03-28-2012, 09:17 AM Thread Starter
cj7guy
I don't think it's the cable. I can hear the electric motor click on when I press down, but nothing happens when I press up. I tried the driver's door button and the button on the LR door, neither worked.
I'll try disconnecting the battery just in case it's a weird Chrysler electrical fluke before I tear apart the door.
cj7guy is offline
post #5 of 37 Old 03-28-2012, 10:28 AM
Davebutch
Very common problem with WJ's and an easy fix. Go on eBay and buy a rebuilt window regulator for less than $100 and install it yourself. If you take it to the stealership, it will cost $400. I found out the hard way. The dealer fixed the first one - I fixed the second one.
Davebutch is offline
post #6 of 37 Old 03-28-2012, 11:44 AM Thread Starter
cj7guy
I already did the driver's door, I guess this one is up. The battery disconnect didn't work, no luck on the freebie.
cj7guy is offline
post #7 of 37 Old 03-28-2012, 11:47 AM
cherojeep
My mother in laws WJ did same thing. pulled out regulator and tested, works both directions. needs a switch.
2004 Jeep Grand Cherokee
2009 Honda Civic Si
cherojeep is offline
post #8 of 37 Old 03-28-2012, 11:54 AM
1AAdam
test at the plug going to the reg. we carry brand new regs for well under $100 for that door if u need one!
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #9 of 37 Old 04-02-2012, 02:44 PM Thread Starter
cj7guy
Thanks for the input.
Does anyone have the pinout information for that door wiring so I can give it some voltage and see what's up?
cj7guy is offline
post #10 of 37 Old 04-02-2012, 03:18 PM Thread Starter
cj7guy
Here's what I'm getting out of the harness that comes out of the door.
cj7guy is offline
post #11 of 37 Old 04-24-2012, 11:04 AM Thread Starter
cj7guy
I took the door the rest of the way apart, jumped 12v directly to the 2 prong plug coming out of the window motor, it went right up.
Clearly the motor still works, what exactly do I need to replace to exorcise this Chrysler electrical demon?
cj7guy is offline
post #12 of 37 Old 05-08-2012, 08:32 AM
iJeepWJ
The wiring harnes in the door panal. Same thing happened to mine
iJeepWJ is offline
post #13 of 37 Old 05-08-2012, 04:25 PM
scottsorensen
this happened to me a couple of weeks ago on spring break. all i had to do was pull the door panel, unplug the window switch and plug it back in, worked perfect since. must have just been a loose connection
scottsorensen is offline
post #14 of 37 Old 01-03-2015, 03:55 PM
THEBAD1
Question.... on the broke wire are we talking the front door or rear? Having same problem
THEBAD1 is offline
post #15 of 37 Old 01-03-2015, 04:44 PM
GTPDrew
2003 WJ
Since you jumped the plug and it worked. It's the solder connections on the circuit board that cracked. This is a very widely known issue with all these window switches. The easiest fix short of buying a new switch is just to re-solder the connection. It is easy to spot the crack and even easier to re-solder. Typically you would re-solder them all while you have the switch out and spray the switch mechanism with contact cleaner.
This fix is all over You Tube if you want confirmation.
GTPDrew is offline
Window help Restruction WJ Grand Cherokee Forum 3 01-25-2012 10:36 PM
Window regulator. liquidxit2 WJ Grand Cherokee Forum 14 08-24-2011 12:30 PM
WJ Window Gap psychobike WJ Grand Cherokee Forum 3 06-14-2011 05:23 PM
Window Problem Overland_03 WJ Grand Cherokee Forum 6 05-18-2011 12:38 AM
WJ window sams WJ Grand Cherokee Forum 2 07-21-2010 10:46 AM
