Low fuel on hill no start - JeepForum.com
post #1 of 4 Old 04-15-2019, 03:40 PM Thread Starter
mustang67ford
I parked on a slight hill yesterday with the nose down and drivers side leaning down sideways. My fuel light was on before i parked. Figured i would get gas today. Well went to start and no go. Tried several times before i added about a gallon then it started. Filled up and took 16 gallons so i had about 3 gallons in it when it didnt start. Now i thought that with a pressurized fuel system, that it would suck up every drop of fuel. I wouldnt have thought i would have this problem with 3 gallons still in the tank. Its a 4.0 I6, fuel pump's about 2yrd old. I would estimate a hill with about a 20% grade.
mustang67ford is offline
post #2 of 4 Old 04-15-2019, 04:01 PM
jtec
jtec's Avatar
2014 JK Wrangler
its not a pressurized system. If anything neg pressure.
As you corrected condition with adding fuel self explanatory what why.
CW* You should NEVER see the low fuel light - this is an example of WHY.
* or old fart thinking what ever you want to call it, 1/4 tank is time to add,
jtec is offline
post #3 of 4 Old 04-15-2019, 04:18 PM Thread Starter
mustang67ford
Thanks for clarifying. Always thought it was pressurized.
post #4 of 4 Old 04-15-2019, 08:46 PM
HarryH3
The fuel gets sucked up by the pump, near the center of the tank. The system is only pressurized from there to the engine. Lose fuel at the pump and a fuel injected engine will stop running nearly instantly. There is a baffle in the tank that keeps fuel near the pump as the fuel splashes around during driving, but in your situation it had time to drain the fuel off to the corner of the tank. Dry pump, no go.
HarryH3 is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3864 10-19-2019 11:58 PM
12 Things You Can Do When Your ZJ Stalls ZeeJay1997 ZJ Grand Cherokee Forum 448 05-28-2019 08:14 PM
Adjustable FPR and cross flow fuel rail on the cheap Cobra Jeep YJ Wrangler Technical Forum 6 12-30-2018 08:22 AM
1998 Cherokee 4.0 Poor Fuel Economy mdtobe XJ Cherokee Technical Forum 14 08-17-2018 08:00 AM
Low Fuel Pressure / No fuel pressure / Slow crank / No start Espiea WJ Grand Cherokee Forum 2 11-26-2017 05:41 PM
